RV.Net Open Roads Forum: Fifth-Wheels: Buzzing sound from converter area
 > Buzzing sound from converter area
ACZL
UPstate,NY
Posted: 05/29/08 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Best way to describe it is a low buzzing sound/noise from the converter area when the coaches overhead lights are on or at times other items being used. I removed the panel and inside cover and it seems to be coming from something behind a panel I cannot see. Once the overhead lights are shut off, the buzzing stops. Any thoughts?
ACZL
2003 F250 SD,CC,4x4,SB,AT,Lariat,6.0PSD
2006 Cedar Creek Silverback 33 LBHTS "Custom"
Member of The Cedar Creek RV Club
"Creekin' in the Summer"
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
DOTLDaddy
Camp Canine, Union, MO. U.S.A.
Posted: 05/29/08 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Fan.
Walter & Garland - Camp Canine caretakers
Gen. Gretchen - 4 y.o. GSD - Special Forces/Seal/DOTL Cloudbusters
Gen. Missy - GSD/Aussie - Special Forces/DOTL Rainbow Division
2003 GMC Sierra 2500HD
2008 Puma 25RBSS TT
Polishnurse
Schodack, NY
Posted: 05/29/08 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Transformer hum coming for the converter. If you wish to go thru a lot of trouble, you can mount it on some rubber pads or cushions. It's proberly mounted on a piece of pannaling and that will act as a sounding board. JM2Cents Bill
Oakman
MO
Posted: 05/29/08 11:55am Link  |  Quote  |  Print  |  Notify Moderator
Probably the cooling fan for the converter.
2002 Dodge 2500 V10
2008 Wildcat 28RKBS
Honda 2000 gen
TomTom One 3rd edition GPS
John3872
Iowa
Posted: 05/29/08 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing to worry about...this is normal. Just the fan kicking in to cool the inverter.
2001 GMC 2500 6.0L
2006 Rockwood 8281SS
Reese 16K Fifth Wheel Slider
DrawTite Brake Controller
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/29/08 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
I agree, fan and/or transformer hum, normal operation for a converter.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
jjfay03
Washington State
Posted: 05/29/08 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same noise, so I went looking for it and it was coming from the transformer. I was satisfied and everything seems to be working good. Mystery solved for me!!
John and Jeannine + 3 Boys 9, 6, and 4.
2007 Dodge 2500, 5.9 CTD LB, Husky Brake Controller,
Husky 20K Hitch, Linex, and Firestone Airbags, Pac Brake.
2007 Keystone Challenger 34' SBH 5er
I can't forget the puppy, Little Boy!
donawilcox
Taylor TX
Posted: 05/29/08 11:58pm Link  |  Quote  |  Print  |  Notify Moderator
Mine starts making a lot of noise when we have a lot of lights on. I shut a few off and it gets quiet again. We typically do not need that much light just kids just do notalways turn off lights in there room or bathroom. Or if have a 2 bulb fixture I shut one off.
Don Wilcox
Taylor TX
2006 Duramax 4X4
2007 295 Cherokey by Forest River
ACZL
UPstate,NY
Posted: 05/30/08 02:34am Link  |  Quote  |  Print  |  Notify Moderator
I can assure you it's not the fan. But the transformer hum is something I didn't think of. Sound goes away when say the overheads lights are shut off, then comes back when switched on. Sometimes it makes noise say if using a fair amount of current/juice. Startled me at first, for I expected flames to erupt anytime.
Thanks for the quick replies folks.
ACZL
Dave H M
IL
Posted: 05/30/08 06:29am Link  |  Quote  |  Print  |  Notify Moderator
AC
I still bet is the transformer fan. It depends on the load. Sometine if I plug my traier to shore power it will come on becsause of the load that it supplies to a low battery. The radio or tv usually keeps me from fixating on it.
