RV.Net Open Roads Forum: Moving up to a fifth wheel and have questions
 > Moving up to a fifth wheel and have questions
gandalf12
Coeur d'Alene, Idaho USA
Posted: 05/30/08 09:39am Link  |  Quote  |  Print  |  Notify Moderator
We have owned two truck campers and plan on buying a fifth wheel for retirement semi-fulltiming. We plan to keep our Citation camper for those out of the way places and boondock adventures we love so much, and plan to keep our 2003 Silverado Duramax 1 ton as the tow beast. We are seriously considering a 31ft Sunnybrook Titan with all the options and need a hitch that we can take out so we can use our slide in camper. Any recomendations as to a removable hitch that does not involve adding height to the bed to get the camper in? The Citation has an aluminum tube frame and the bottom is raised about 1.5 inches on the botttom bars.
Gandalf12(copilot Kathy and the doggies)
2003 Silverado 3500 Duramax; Ride Rites; Rancho 9000x; Helwig rear swaybar;2003 Citation Supreme 10'4"/slider
Murgatroid
NorCal
Posted: 05/30/08 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Easy. B&W turnover ball hitch system with the Companion 5th wheel hitch. It's easy to remove and leaves nothing in the bed of the truck. It's very beefy and well made.
-steve
2009 Sundance 2800RLS
2006 Dodge Ram 2500 QC LB CTD
B&W turnover ball hitch with companion
Champ198
Lebanon, Tennessee
Posted: 05/30/08 09:49am Link  |  Quote  |  Print  |  Notify Moderator
There are several options for under bed rail mounts. Link to Husky site This keeps the bed clear when the hitch is out. Hope this is what you're looking for.
Duane & Amanda, a teenager, A golden retriever named Jazz, a crazy pet rabbit named Stew, and now Optimus Prime the hamster.
2008 Cedar Creek Silverback 30LSA
2008 Ford F250 Lariat SC 4x4 PSD 6.4, Timbren SES, Husky 16k Slider
gandalf12
Posted: 05/30/08 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Murgatroid and Champ198!! I probably will have many more questions for this forum as we enter the fiver scene! Backing up a 31 ft trailer is going to take some getting used to also. Now, with the camper (we have a backup camera) getting into and out of parking lots and campgrounds and tight spots is pretty easy but with a tail as long as that...
CampingUSA
California
Posted: 05/30/08 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Pullrite also makes a hitch that hitch rails remove completely from the bed. Not cheap, but it is a great hitch.
chrizg
IA
Posted: 05/30/08 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have the B&W and I second it. Its a bit pricy but it leaves nothing in the bed once out except for two U shaped peices that have springs if you need to chain something down, and those don't stick up at all.
09 Big Country 2950RK
06 Dodge 3500 CTD 4X2 Mega Cab DRW B&W
dmax27
Middlesex County , MA.
Posted: 05/30/08 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
If your hitch has bed rails, couldn't you just put in a 1 inch thick mat in the bed cut around the rail? Your camper would sit on the mat and it shouldn't cause any damage to the camper.
Dmax 27
2001 2500HD LS D/A crew cab 6 1/2 box
K+N filter, Borla 4" s/s exhaust, Edge Juice/Attitude, Rear
Air Ride load levelers, 285/75r16 Bridgestone Dueler REVO
2002 Cedar Creek 33RLTS 5TH Wheel
2006 Fourwinns 220 Horizon 280 HP
JustLabs
Washington State
Posted: 05/30/08 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
I've got the Pullrite Super Fitfh with the Super Rails. You're correct about it not being cheap,but its very easy to remove and store when not being used.
The hitch comes apart in 2 pieces so you're not hefting the entire hitch all at once. The rails come out of the bed with 4 pins.
Takes maybe 5 minutes to remove.
2007 Dodge Ram 3500 SRW,4x4,Cummins 5.9, 6spd.
2007 Keystone Cougar 289BHS Fifth Wheel.
