RV.Net Open Roads Forum: Tech Issues: LP generator hard to start
 > LP generator hard to start
billltrv
Greensburg, PA
Posted: 05/30/08 10:42am Link  |  Quote  |  Print  |  Notify Moderator
I have a 1996 Coachmen Class C Leprechaun Diesel. The last time the MH was registered was 2005, so I assume this is the last time the generator was run. It has a 3.6 Onan LP generator model 6KYFA26120E with 100 hrs. The generator is very hard to start at times, however, when WD40 is sprayed into the carburetor the generator easily starts {tips from Gunny357 forums} and runs great and restarts easily after shut down until the next time it is needed resulting in hard to start without WD40. It ran perfect for over an hour shutoff and restarted without any problems. What is causing this starting problem when the generator hasn't run for a while? Any help Thanks Bill
jauguston
Bellingham, WA
Posted: 05/30/08 11:59am Link  |  Quote  |  Print  |  Notify Moderator
There are a lot of things it could but I found when mine got hard to start I found the large propane hose that went from the regulator to the carb had a low spot that had accumulated oil that had come out of the propane and was restricting the very low pressure propane flow. I dumped the oil out of the hose and the problem was gone.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
275 RV injectors
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
ArmySFCRet
Elfrida, AZ
Posted: 05/30/08 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
Oil in the system is a major problem with LP gensets. We had to have ours rebuilt under warranty ($927) because we got some bad LP on a trip. There should be a valve on the carb that you need open and drain often (every other month depending on use). Check your owners manual or go on line to find that valve.
Hitting the road with:
'04 Cross Country 35' w/300 Cummins
KarKaddy 460SS '05 Sebring CV
8 year old GS and Mattie the Lhasa
Good Sam Lifetime Members
See over 300 Classic Hudson, Essex and Terraplane Automobile photos on our Hudsons on the Web site.
gunny357
North Carolina
Posted: 05/30/08 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
Bill:
Liquid or vapor withdrawl?
Liquid usually take a little more cranking for a start if they haven't run in a while.
If vapor, look to the demand regulator which will be a large, thin, flat device. There are a couple of vents on them that sometimes get clogged with insect nests. For some reason mud daubers and spiders seem to like to hang around those things. Be sure the vent, there may be 2 of them, are clear. Those regulators can be a little difficult to get adjusted properly, PM me and I'll tell you how I do them.
If vapor, how is this demand regulator mounted? horizontaly or vertical? Onan did mount them horizontally for a while and found that wasn't a real good idea.
Demand regulator might be sticking, oil from the propane wil foul them eventually, wouldn't think so with 100 hours but then it is possible.
purplepossum
Virginia, USA
Posted: 05/30/08 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
If I go too long between start ups on my propane generator on the TC it is very hard to start. Since I also turn off the tanks during storage I think the propane bleeds out. The generator is tail end Charlie on the system. I've learned to light the stove and then turn on the heat. The generator is after the heater.
