RV.Net Open Roads Forum: Tech Issues: Honda EU1000i vs EU2000i
 > Honda EU1000i vs EU2000i
bonscott
Michigan
Posted: 05/30/08 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
So I'm looking to get a generator for the following reasons:
1) To recharge PUP battery while dry camping/boondocking.
2) To use as an emergency power source if the power goes out at home. I would plan to run only the fridge, fans or electric heater, maybe a computer or TV.
Would the 1000i be enough for this?
For me weight is a big issue as with my bad back the 1000i would be much easier for me to handle then the 2000i which appears to weigh about 50 lbs. But I'll deal with it if the 2000i is a better fit for my needs.
Scott
TV: 2004 Kia Sorento
Popup: 2004 Flagstaff (by Forest River) 227
RJsfishin
Winston Or.
Posted: 05/30/08 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
The 1000 will run a small electric heater (750 watt) and thats all. So if you want to run anything more than that, you're into the 2000.
Otherwise the 1000 will run lites and charge the batteries just fine, if you don't try to charge over about 50 amps.
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
bldrbuck
Boulder, Colorado
My experience is that an EU1000 will not power a heater. It only puts out 800 Watts, The EU2000 till run the heat only. I have a Yamana 2800 and it does the job very well but does weigh 50 pounds and is not as quiet. The Yamaha 2400 would be my choice if I was going to buy at this time. Good luck
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
Keith M
Cle Elum
Posted: 05/30/08 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
You cannot run an electric heater with a Honda EU1000 and even with the 2000 most electric heaters draw about 1300 watts. That uses almost all your power. Here is what I ran during a power outage a light 60w, a TV-120w, sat dish-45w, a very low powered fan for an oil heater, and the refrig which might be 450w. The EU1000 was pretty well maxed out. You have to have a newer refrigerator like less than 5 years old that doesnt have a compressor that draws a lot of juice on startup. I would get the 2000 W. I have both and the 2000 adds some options.
smkettner
Posted: 05/30/08 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
How often does power really go out? I would get the 1000 and live within the limitations. Good chance that it will not be able to start the fridge compressor. The 1000 is rated 900 watts for running a heater. For an extended outage you will just have to live in the pup.
ljr
Pennsylvania
Posted: 05/30/08 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
I've used my 1000 for furnace fan, lights, TV and fridge many times. If I plug in a toaster, forget it. So I'm betting against an electric heater.
Larry
Wayne Dohnal
Banks, OR.
Posted: 05/30/08 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
If somebody from another planet read this thread they'd assume all space heaters have the same current draw. I think an eu1000i would run my 400 watt oil filled heater just fine, as well as the big one set to 600 or 900 watts.
2009 Fleetwood Icon 24A
EU2000i generator
352
Oxfofd, Fl
Posted: 05/30/08 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
$860 delevered no tx for the 2000 here
1937(BAD BOY)pontiac,all steel,chevy 350,dyno=405hp,650 holley double pumper,ps,pb tilt wheel,heat & air,
700 r4 tranny,headers,3" exhaust with flowmasters.
just a good ole southern redneck country boy.our favorite place to go to swim with the manatees
smkettner
Posted: 05/30/08 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
What does the 1000 cost? Just for comparison.
352
Oxfofd, Fl
Posted: 05/30/08 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
click on the link and call them
