RV.Net Open Roads Forum: Class A Motorhomes: Drooping Window Seal Corners
 > Drooping Window Seal Corners
daddoe
Orange, CA
Posted: 05/30/08 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
While walking around my RV I noticed the black rubber seals on the outside of a couple of my windows appear to be "pulling" away from the top round corners. I figured it was because my motorhome is aging, but then I noticed the newer class C next to me doing the same thing.
Is there something like an adhesive that I can apply to the seal to hold it in place at the top corners of my windows?
daddoe
1994 30' Fleetwood Flair
Wife, 2 Kids and Kenji our dog
happyeaglesfan
Pottsville, PA
Posted: 05/30/08 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Good question? I do not have the answer but am interested in what others have to say. I have noticed this in my TT and it is only 6 years old? I thought about a flexable calking but am not sure?
2006 CHEVY 2500HD 6.0L 4.10 Ext Cab
Wife, 3 kids (boys... 6 month old, 5 year old, and 6 year old), and our dog RIGZ.
Ken Washington
Pleasant Garden, North Carolina
Posted: 05/30/08 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
There has been a lot of discussion on this forum about this problem! This can not be fixed and some have replaced their windows to fix this problem. This has been happening for some time now and unless it is under warranty you are stuck with them.
Ken
2004 Patriot Beaver Gettysburg
Cummins ISL 400HP Turbo Diesel
Allison 3000-MH 6 Speed World Transmission
Roadmaster M-Series Chassis
TOAD-2005 Honda Element
Bob&Billye
Pueblo West, Colorado(Spring-Fall)Tucson Az(winter
Posted: 05/30/08 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
I just had mine fixed yesterday. Same problem. Took it to my auto glass company(I am probably their fav customer as I have a magnetic personality....I attract rocks aimed at our auto and rv windshields). They put sealant on it at no cost and said that should fix it. Only time will tell if they are right.....but have seen these guys in action for a number of years....and they appear to know their business.
Bob and Billye
Bairne the dog and Max the cat
Retired USAF
2003 Winnie Journey DL 36
Towing 2007Honda CRV
Raodmaster Falcon 5250 Tow Bar
Brakebuddy Vantage tow brake system
RamblinFever
Ontario, Canada
Posted: 05/31/08 06:24am Link  |  Quote  |  Print  |  Notify Moderator
I have the same "droopy" problem on a couple of bedroom windows. However it appears to be an internal rubber spacer that is drooping as the seal integrity still seems to be OK.
04 Bounder 35E, W-22
05 Honda CR-V, SMI brake
daddoe
Orange, CA
Posted: 06/01/08 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Ken
Sorry, I did a search and did not see anything specific to my issue. I found some posts dealing with double paned windows, but my windows are only single pane. Seems like overkill to replace perfectly good windows because of a few small outside rubber seals?
Gjac
Milford, CT
Posted: 06/02/08 06:59am Link  |  Quote  |  Print  |  Notify Moderator
I think the drooping seals are caused by the rubber shrinking. I fixed mine by sliding the rubber up to the drooping corners. This left a space in the center where the rubber is split on each side of the window posts. I filled in the space with black butal rubber. The same stuff I used to seal the windows fames to the outside of the M/H.
zipp
Centerville,Ohio 45459
Posted: 06/02/08 10:04am Link  |  Quote  |  Print  |  Notify Moderator
I HAVE TO ADMIT I'M NO EXPERT, BUT I HAD THE SAME PROBLEM ON MY DRIVER AND PASSENGER SIDE WINDOWS, DOING WHAT WAS described here. This is what I did, about two weeks ago and it is stiil holding. I went to Autozone and bought the adhesive that you use on rubber seal for your car doors. They have yellow or black colors. Hope this helps,
Denny & Mighty Wife
2002 Dolphin 5356
Towing 2004 Trailblazer
daddoe
Orange, CA
Posted: 06/02/08 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Denny, I'll have to give that a try. Thank you everyone for your helpful suggestions.
