Acampingwewillgo
Camarillo, CA
I shut down Both, at the park pedestal and in the coach. Someone once said(probably on here) that was the proper procedure and its my routine now. Cant see it hurting anything.
96 Vogue Prima Vista 37' 350/10.3 litre CAT 3176B, Webasto heat, Howard Steering, 10KW Power Tech.
Mollie (our Baby)
FMCA Member
Rally's- 11 and 1 GNARV Rally
yakman
Carbondale, IL
I always test the outlet for proper wiring and voltage before plugging in. Had an electrician recently wire a 50 and 30 amp box where I keep my RV on my farm. He miswired the 30 amp with the ground hot and the hot to ground. He thought he was wiring a 240 volt washer/dryer outlet.
Democracy is two wolves and a sheep deciding what's for dinner.
CactusJohn
Scottsdale, AZ
I agree with yakman. I always test the park pedestal with my Digital AC Voltage and Polarity Tester before I start leveling and setting up my 5er. When I’m ready to connect my cord, I turn the pedestal breaker off until I've connected both ends.
2007 Ameri-Camp Summit Ridge SF27RK 5er
2008 F250 Lariat SuperCab, 6.4L PSD
Reese 16K Kwik-Slide with BedSaver
NanciL
Bakersville, NC, USA
The proper way to plug in any cord, (including your small 120 volt house hold cords) is to have all loads turned off.
If there is a load turned on, especially a large one like an Ac unit, there is a surge of power and you will be subject to sparking, just as the prongs of the plug touch the socket blades.
Jack L
Jack & Nanci
Rick Jay
Greater Springfield area, MA
Ditto what the yakman said about testing the outlet first. I always check the voltage and polarity at the pedestal before plugging in. Whenever the shore power cord gets plugged in or unplugged, the breakers at the pedestal are OFF. If there is a chance my air conditioners might be turned on, I'll make sure they're off before throwing the power back on.
~Rick
edited 05/31/08 06:28am by Rick Jay *
2005 Georgie Boy 3625 DS on a Workhorse W-22 (Class A)
Rick, Gail, 1 girl (12-Angel), 1 girl (7), 2 boys (8 & 5), 1 plump Golden Retriever.
2001 Honda Odyssey with Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
ShapeShifter
Buffalo, NY
Acampingwewillgo wrote: I shut down Both, at the park pedestal and in the coach. Someone once said(probably on here) that was the proper procedure and its my routine now. Cant see it hurting anything.
From an electrical viewpoint, I agree, I can't see it hurting anything. The one possible downside I see is mechanical: most breakers are not designed to be turned on and off frequently, they may wear out early.
There are some industrial and commercial applications where lights and other loads are routinely controlled by flipping the breakers on and off. In these cases they should be using switching grade breakers, which are more substantially built, and more expensive. But I can't see an RV manufacturer using them, because of the extra cost.
I believe just flipping the one on the pdedstal is sufficient.
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
Mudflaps
Kempner, Tx
Have to agree with checking the voltage. I also shut off the pedestal breakers before I plug or unplug the cable.
2002 F350 PSD CC LB DRW
2003 323I Everest
DavesWife
Homer Glen, Illinois
Is this step necessary for all RV's, including TT? Or is it just 50amp motorhomes? Nothing is on in our TT while traveling. Mem Day Weekend I plugged in and Hubby scolded me for not turning off the pedestal breaker first. Nothing happened, no spark or anything....
Keystone Sprinter 311BHS
2007 Silverado 2500HD 4x4 4.10
shooters
Southern Calif
Guys,
thanks for all the response. I really appreciate ya all taking the time to give me some very helpful information. Great site here. Stay safe and have an awesome summer.
Shoots
Retired Phone Man
Covington, Louisiana
DavesWife wrote: Is this step necessary for all RV's, including TT? Or is it just 50amp motorhomes? Nothing is on in our TT while traveling. Mem Day Weekend I plugged in and Hubby scolded me for not turning off the pedestal breaker first. Nothing happened, no spark or anything....
I have a TT with 30amp service and I turn off pedestal breaker before hooking up. Your 12v converter is always "on" and just waiting for some AC power to start up so you will have a load when you plug in.
2007 Toyota Tundra SR5 Double Cab with 5.7L V8 and Tow Package.
2007 Gulf Stream Ameri-Lite 21MB
Peaches - Lhasa Apso/Mut Mix
