RV.Net Open Roads Forum: Fifth-Wheels: Fridge?
 > Fridge?
GBuilders
Boerne TX.
Posted: 05/31/08 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
I have a norcold in my Eagle and have been very happy with it so far but have a few questions.
Is it better for cooling to have the fridge full or empty?
How important is it to level the 5th while using the fridge?
I have noticed that when the unit was new the freezer seal was very tight especially after you closed it but now it's not as tight but seams to work fine.
Thanks for you help
2007.5 Dodge Megacab DRW 4x4 6.7 w/6 speed auto, 3:73 & prodigy BC
2005 Jayco Eagle 305 BHS
2oldman
WA
Posted: 05/31/08 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Completely empty, but what's the point? You don't want it so full that air cannot circulate.
Level enough to live in it comfortably is the general rule.
fuzzbutt
Pittsburgh
Posted: 05/31/08 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
If you overstuff the fridge, the air won't circulate and it won't cool as well.
I had a problem with mine last weekend. It was 4 degrees off level and wouldn't work right. I shut it down. When I levelled it off back home it worked fine.
John, Sherry & Sabrina
+ Mowgli (Keeshond) Sunny (Sun Conure) & Lily (Cockatiel)
94 Winnebago Adventurer 34'
04 Nissan Murano
98 Subaru Forester
92 Honda Gold Wing
Now.....bring me that horizon.
CactusJohn
Scottsdale, AZ
Posted: 06/01/08 01:09am Link  |  Quote  |  Print  |  Notify Moderator
You might want to consider getting a Fridgecool Fan to keep the air circulating so the temperature is evened out in the box.
2007 Ameri-Camp Summit Ridge SF27RK 5er
2008 F250 Lariat SuperCab, 6.4L PSD
Reese 16K Kwik-Slide with BedSaver
 > Fridge?
