RV.Net Open Roads Forum: Travel Trailers: Grey Water Fills in 3 Hours!
 > Grey Water Fills in 3 Hours!
Page of 10
Opie431
Bellevue, MI
Posted: 06/02/08 06:25am Link  |  Print  |  Notify Moderator
If it is not blocked can you wash dishes outside and dispose of the water where
ever the campground wants you to.At a private campground you may not be able to do that. At home give each family member a gallon jug of hot water and try taking a shower with that. Or put the plug in when someone takes a showere at home and see how much water they use.
Fordlover
Spring, Texas
Posted: 06/02/08 08:34am Link  |  Print  |  Notify Moderator
I'd say find a place where you can hook it up to a sewer connection (I can do this at home in my driveway) And then open the grey tank. Then hang out in the trailer using water everywhere. If it starts to back up, you've got a big issue. if it all drains like it's suposed to, then you guys are using too much water or your tank isn't holding 40 gals.
02' Ford Explorer 4.6 V8 4x4, prodigy and equalizer
07' Crossroads Sunset Trail ST19CK
03' Ford Focus SVT my daily driver
04' Volvo S40 wife's daily driver
lowryfarm
Salisbury, NC
Posted: 06/02/08 10:07am Link  |  Print  |  Notify Moderator
If you just bought it then I would take it back to the dealer and have them show me what I'm doing wrong. They should have done an extensive walk through with you when you bought it but maybe they (or you) missed something.
grump daddy
Westland, MI
Posted: 06/02/08 10:08am Link  |  Print  |  Notify Moderator
rlanger2 wrote:
sbingham wrote:
My guess is the valves are still set for winterizing. They need to be opened! That is, you are only filling the pipes and not the tank. When you empty next time see what comes out. Gray water should take 3-5 minutes to completely drain. You can hear it and see the hose wiggle.
That sounds like it would make sense...how do I open them?
I'm sorry but I don't think there is such a thing as a shut off valve on the actual water drains. There are shut offs for the water system coming into the water heater and incoming water lines from the fresh water tank, but none on the drain lines. Check the vents on the roof.
andya
Plainwell, michigan
Posted: 06/02/08 06:20pm Link  |  Print  |  Notify Moderator
By now you probably already have your answers, but in case you don't, I'll give you my thoughts. Since your kitchen sink backed up, but the shower didn't overflow onto the floor, it seems you may have two grey tanks, and probabilities of both being clogged are remote. So in that regard, I'd say someone re-plumbed your system for direct drainage, like for a seasonal hookup, which brings it back to having just one grey water tank. You and your friend didn't buy the campers from the same dealer did you ?? Maybe both are rigged up the same way for the same reasons?? Anyway good luck, in this fix and future camping.
Skyline Layton 2500
1997 GMC 1500
FunNut
Phoenix & Santa Fe - USA
Posted: 06/02/08 07:08pm Link  |  Print  |  Notify Moderator
I'm brand new to RVs and this is a most interesting thread. Could it be that the tanks are clogged with "muck" of some kind? This would be more logical if the problem was in the black tank, but it seems a possibility.
I would certainly head back to the selling dealer and let them sort things out. Whatever the outcome, PLEASE post the end results/solution when you figure out what's going on.
LAdams
Northern Illinois
Posted: 06/02/08 07:10pm Link  |  Print  |  Notify Moderator
HUH Your speaking of the HW bypass system and that won't have anything to do with this problem...
I looked up some Timberline units and although I didn't find any 19' models, I did find an 18' model and it indeed lists a 40 gallon gray water tank...
Here are the specs and floorplan of that unit:
Gross Dry Weight (lbs) 4140
Fresh Water Capacity 50
GVWR (lbs) 5600
Grey Water 40
Net Carrying Capacity 1035
Black Water 34
Hitch Weight lbs. 460
LPG Tank Cap. (lbs) 40
Length 23' 1" Awning Length 13'
Width 8'
Height 10'
If your filling a 40 gallon gray tank with one shower and a few sinkfulls of dishes, something is wrong somewhere... It could be that the vent pipe has dropped into the gray tank and won't fill all the way... I would look at the gray water tank if you can see it under the TT... Measure the tank and then multiple the length X width X height in inches and then divide that figure by 231... That will give you a pretty close approximation of the tank capacity... I'm wondering if someone didn't change the tank due to damage or whatever reason...
* This post was edited 06/02/08 07:29pm by LAdams *
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
** NEW ** blog.rv.net
wayne_tw
South Dakota/Georgia
Posted: 06/02/08 07:22pm Link  |  Print  |  Notify Moderator
Since these are new Rv'ers, I bet these folks are just using way too much water. I know they said they used military showers and just a sink of water, but I bet somewhere the water usage is over the top. Empty the tanks, then with a 5 gallon bucket, fill it and dump it into the tub. Add up how many buckets it takes until the tub overflows. Let us know the answer. Then we can give sound advice rather than just speculating.
LAdams
Northern Illinois
Posted: 06/02/08 07:31pm Link  |  Print  |  Notify Moderator
Could be I guess
Les
19Sandie54
AZ
Posted: 06/02/08 07:32pm Link  |  Print  |  Notify Moderator
I agree...especially with kids. We are constantly on our grandkids about leaving the water on so long.
JJ & Sandie
Li'l Jack and Pickles, chihuahuas...Chewy, poodle 6/15/95-7/4/08 We will always love you Chooch.
2003 Chevy 2500HD,LT,CC,SB,4x4,Duramax/Allison
2007 Starcraft Homestead 262RKS
Page of 10
