RV.Net Open Roads Forum: Fifth-Wheels: Tire wear
 > Tire wear
lv2rom
Kansas City, Missouri
Posted: 06/02/08 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Well...lets start by elimination...
--excess weight would cause INSIDE tread rib wear
--a bent axle (they usually bend upwards) would also cause INSIDE rib wear.
--a loose or worn bearing (unless it is the inside bearing..rare!) would also cause INSIDE rib wear
--A loose or worn U bolt would allow the axle to rise and result in INSIDE rib wear
--loss of pressure would result in wear on the INNER and OUTER ribs
Soooooo.....about the only thing I see that might cause outside rib wear on a single wheel is the previously mentioned misalignment. That mount may be mounted a little forward causing that wheel to scrub (outside to inside) and take off the outer ribs of the tread. Just my analytical 2cts....Brian
2005 F350 Dually -AFE air box/MRSP exhaust/Bags/Bilsteins/Energy Susp./Michleins
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs
1996 Layton Fiver 21ft. Totally reconditioned..Love it!!
CactusJohn
Scottsdale, AZ
Posted: 06/02/08 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
I had excessive wear on the outside of my front passenger-side tire. Turned out it was a bent axle spindle. The shop told me that a bent axle spindle usually causes wear on the inside, so mine was an exception to the general rule.
2007 Ameri-Camp Summit Ridge SF27RK 5er
2008 F250 Lariat SuperCab, 6.4L PSD
Reese 16K Kwik-Slide with BedSaver
 > Tire wear
