RV.Net Open Roads Forum: Towing: ford Super duty brake controller
Search only in Towing
Open Roads Forum  >  Towing
 > ford Super duty brake controller
swebber
Brunswick , MD
Posted: 06/05/08 05:23am Link  |  Quote  |  Print  |  Notify Moderator
Steve, take it to another dealer. When buying my last three trucks I had three different offers on each trade in of that time. Hagerstown Ford was the winner in the last two trades as they offered me almost two grand more than the Frederick dealer.
Be sure to get what you want when you buy...I did this time and I could not be happier.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
gouldc
Edmonton, Alberta Canada
Posted: 06/05/08 09:27am Link  |  Quote  |  Print  |  Notify Moderator
I second that. Seems like a long list of options not included. The fact that you mention them means you'll miss them. If you settle you will be trading in no time.
03' Lariat F350, 6.0L Short Box *SOLD*
04' Jayco Eagle 28FKS *SOLD*
08' FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
07' Keystone Raptor 3712TS PICTURES
Reese 18k Signature Series Hitch
glsurrat
Virginia
Posted: 06/05/08 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
I like the way it works in conjunction with the transmission braking in my '06 F-350. And with triple axle disc brakes on the trailer, stopping my 26,000 lbs is no problem.
Greg
Full-timing and soon to be retired US Navy Master Chief
Enjoying Champagne on the King Ranch!
'06 King Ranch F-350 Dually Diesel 4x4 Long Bed Crew Cab w/ Tow Boss
'07 Champagne Edition NuWa Hitchiker 3 axle 4 slide 37CKRD /w TrailAir all around
RPFAN
Poughkeepsie NY
Posted: 06/06/08 05:05am Link  |  Quote  |  Print  |  Notify Moderator
That dealer wants to be in your pocket on the way and the way out, You should expect no less than wholesale for that truck on a trade. I wouldn't give him my business if he's giving me the business!
Rich
Rich, Fern, Bethany, Justin. 2005 Ford F450,Lariat, 6.0 PSD,CC,DWR,4WD, Air Hitch, 100 Gallon Aux fuel tank.
2007 Cedar Creek Silver Back 35L4QB
Our "Condo in the Woods"
Leave no roller coaster unridden!
Campinfan
Washtenaw County, Michigan
Posted: 06/06/08 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Fords offering A plan pricing to everyone--at least here where I live. Great deal
________
2008 F 250 FX4 4WD, V10, 4.10 Tow Command
35' 2007 Crossroads Cruiser CT32SB
Wonderful Wife and 3 small kids
johnthecamper
Grapevine, Texas
Posted: 06/06/08 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
I love mine. As others have said it is so smooth you hardly know its working. If you are buying new get the power towing mirrors and the backup camera.
08 F250, 08 Jayco 29D
JBarca
Dublin, Ohio, USA
Posted: 06/06/08 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
RPFAN wrote:
I have an 05 F450 with it. It did take a little getting used to as other have said, you can't really feel it. I also run mine near the top 9.0. Also if you are looking at a used one built prior to 3/05, they were made NOT to work under 15 MPH, even while applying manually. Ford will change it out if you complain the right way, I know, I did it.
Rich
First to the original poster. I have gone from the Jordan in my K2500 Suburban to my 2005 F350 with the Tow command. I'm pulling a little over 9,000# loaded TT. The gain is at 8.5. Which I was concerned about but it seems others are doing this as well.
The controller does work well. It is hard to have the TT lead the truck or it so smooth I can't tell. It works as one unit. Fast or slow. Edit: I messed up the who is leading who...sorry
Now to RPFAN. Yes I happen to have one of those pre march 05's and I did not realize the controller will not lock the brakes under 15 MPH. I had just adjusted the TT brakes and wanted to do a drag test on my gravel drive way to see if all 4 where even. Well it would not lock, heck it only puts out 1.5 volts.... at slow speed. I about tore the truck apart trying to trouble shoot what was wrong. I even plugged my Jordan in to test the truck wiring. Ford made it easy to unhook the power cable on the tow command and I could tap in.
Thinking I had a bad controller, I went onto the Ford Truck forum and searched. Sure enough the pre march 05's do not lock. ERRRR I also have the shop manuals on this truck and then I too looked it up there and sure enough it will not lock.
This in my mind is a problem on how in the world to do a drag test. Both on a TT or a 5'er?
RPFAN what technique did you do to get yourd changed? Did they down load a new program to it or change it?
I bought mine used last fall and did not know of the issue until this spring. I do not know how much a leg I will have to stand on to get it changed out. Folks in PA have to bring a specai letter with them to exlain to the TT inpector the brakes will not lock during TT inpection testing the brakes. Have to use the breakaway switch.
PS my 2005 also has a grade braking in tow haul mode when you tap the brakes and slow down. Works good. The 5 speed works good too.
Thanks
John
* This post was edited 06/07/08 07:51am by JBarca *
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we where camping!)
mosseater
Dillsburg, PA
Posted: 06/07/08 07:07am Link  |  Quote  |  Print  |  Notify Moderator
I`m no finacial wizzard but, that`s how I see it too. Regardless of what I payed or how much I owe, the truck still has intrinsic market value. Granted, it may be lower right now because trucks aren`t moving, but I think 17k is just rediculous. And interest is up to 7.99. I`m locked in at 1.9 right now. I haved seached high and low for a trade, both locally and on the internet, and V-10s in any configuration are like hens teeth. I may have to order one if I really want one. I went through about 30 pages of Ford regional inventory online and came up with zilch, so I think the dealer is being straight with me on availability.
Sunset Creek 298 BH
BAJA X
Minnesota
Posted: 06/11/08 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
If your looking for a f-250 or f-350 with a v-10 there's a bunch here in Minnesota, I bought a new one last week and finally got a chance to tow my trailer today and wow what a difference from my 02 250 v-10 this new one pulls it nice have my integrated brake controller set at 4.0 and it stops it like a dream.
08 F-350 4X4 Crew Cab Lariat Super Duty V-10 Tow Command 4.10
Tow Beast Receiver 1700# Reese W/D Dual Cam sway
08 XT30SB CrossRoads CrossForce
04 650 Baja X
04 400 XT Outlander
89 Springer Softail
N9MB
Indiana
Posted: 06/12/08 02:32am Link  |  Quote  |  Print  |  Notify Moderator
Love the brake controller. Pulling 14,000 + lbs set at 8.5 stops with no pushing or jerking at all.
F350 PSD CC DRW Tow Boss
Heartland Bighorn 3600RE
Airsafe Revolution
