RV.Net Open Roads Forum: Anyone had problem with dual cam hitch off road???
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > Anyone had problem with dual cam hitch off road???
famfun
southwest
Posted: 06/03/08 11:02pm Link  |  Quote  |  Print  |  Notify Moderator
Looking at getting a dual cam sway control to add to my wd hitch. Worried about how it will react to when truck is twisting one way and trailer another???? Don't want to spend the money on a totally new hitch (equa-l-izer).
thanks roger
dedmiston
So Cal, USA
Posted: 06/04/08 12:50am Link  |  Quote  |  Print  |  Notify Moderator
Never had a problem.
Wait, shouldn't say "never". I had a problem on a paved road once. Hung a u-turn on a narrow road and cut it too close. It caused one of the WD bars to fall off. I didn't notice until it was too late. I went back, but never found the bar. Called Reese and they said it was their defect. They sent me out a new bar and a new replacement hitch head to fix the problem.
No more trouble on or off road.
2004.5 Dodge 2500 Diesel • 2005 Weekend Warrior FS2600
Toys:
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
  • 06 Yamaha TT-R90E
The Edmistons - Our Gallery
Never forget 9-11-01 Check out our blogs @ blog.rv.net
famfun
southwest
Posted: 06/04/08 01:26am Link  |  Quote  |  Print  |  Notify Moderator
what about reese pro series sc hitch?? anyone tried that....
roadglide3
Erie, Pa
Posted: 06/04/08 08:04am Link  |  Quote  |  Print  |  Notify Moderator
That's what I have. The only thing that the dealer said to me was to make sure you disconnect the WD bars before going offroad. I like the way it eliminates the need for a friction sway bar and I have had no problem with it so far.
2006 Chevy 2500 HD 6.0
2007 W.W. FSC 2800 Billet
2002 HD Roadglide
2006 Yamaha 660 Grizzly
famfun
southwest
Posted: 06/04/08 09:02am Link  |  Quote  |  Print  |  Notify Moderator
I would not even consider towing my trailer with the bars disconnected( 30ft 11,000lbs). So that is not an option.
roger
Jim&Peg
Central Ohio
Posted: 06/04/08 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
Regardless of the brand of WD hitch, I think the major concern is going through a deep dip. This puts extreme stress of everything and could over-flex and bend the WD bars, bend the trailer frame, bend the TV frame, etc.
LanceUppercut
So Cal
Posted: 06/04/08 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
I have a similar sized trailer (28'/12000 lbs) and I have never had a problem off road. I leave them hooked up tight and I am not exactly easy on them. I have done some pretty good twisting too. They work great on road too.
2006 Next Level 28CK
2006 GMC Sierra CC/SB 4x4 D/A LBZ
2005 CRF450R
famfun
southwest
Posted: 06/04/08 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
Just ordered a Equa-l-izer. roger
sdmotor
Chula Vista
Posted: 07/10/08 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
I have taken my bars off for a few short off road trips. I doubt it will hurt anything for tight U-turns or getting the trailer to that great dry camping spot.
Getting there is half the fun....
s@ndm@n
Moorpark, CA
Posted: 07/10/08 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
i've been told to pull the bars when going off highway... however, i rarely listen to what i'm told. I have only pulled them off once at pismo to put some weight on the rear axle. Never had a problem using them off road.... even down Rasor Rd...
I have seen a class A pulling an enclosed that bent it's tongue bad with it's wd bars on.... not a pretty sight.
2008 F-450 Lariat 4x4 w/4.88s
2006 Coachmen Adrenaline 274FS
2000 Honda XR400 Dual Sport (CA plated) (me)
2006 Honda TRX450ER (wife)
Lots of other toys too....
2 daughters + Shadow the dirt dawg
THH
