OldBaldGuy
The wilds of Arizona for the winter
We are pretty new at this fifthwheel stuff, just moving there after owning a couple of Class A's. Yesterday I was backing into a site, from the drivers side, and noticed that the front axle of our '07 Open Road 35' has shifted toward the curb side of the tlr a couple of inches! Pull the thing into a straight line and it went back where it belonges. Scared the******outta me! Is this normal, or do we have major problems???
OBG
JRSFamily
Auburn, WA
Yes, it is normal. The axles tend to bind and twist when making sharp turns.
2005 Idle-Time 5th wheel
2001 Ford F350 4x4
Es nos illic etiamnunc?
kennethwooster
Perryton Tx USA
Yes they will move. I got excited about my 2007 Quantum, because even when straight it was off just a little. I don't know if this was the problem or not, but Mor Ride had to do a rework, because there was so much flex it was breaking and then breaking the frame on the trailer. They had to put braces on the system, as well as space the tires further apart.
Had to order new parts from Roto Chock to make them fit. Pearl took great care of me.
I'll be glad to see how much flex I will now have.
kenneth wooster- farmer
wife Diana-adult probation officer
365BSQS Quad slide 2007 Quantum
Ford F350 2005 model, 4X4 FX, King Ranch
18K SuperGlide Hitch
OldBaldGuy
Thanks! I was worrying so much hair was falling out, and I can't afford that!!!
larry barnhart
wenatchee. wa usa
It is a good idea to back up and pull ahead before unhooking so the axles won't have a bind because of the twisting you saw. chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
randy&shereen
Jackson, MI
The twisting you saw is also the reason to replace tires after 5 years regardless of wear. Belts that make up your tire will fatigue and separate due to side loads. Randy
2004 GMC Sierra 2500HD SLT CREW CAB LONG BOX (7380#)
8.1 Big block Gas/Allison 4:10 4x4
2004 Newmar Kountry Star 34 BLWB 3 Slides (15620#)
Pin Wt 2560# (16.3%) Total combination Wt=23,000#
lc51willy
Fulltime USA
It is not really the axles but the tires flexing side walls.
You should watch a 3 axle backing into a site. Or even turning a corner.
Larry
USA TRAVELER
LC&KC
MOJO (Deceased 4/10/06)
2000 International 4700 CREWCAB 530 power/Full Air ride cab.
JAKE BRAKE/ Gvwr 23,500
40ft. Prowler AX6 4 Slides/Trail Air Pin Box/HughesNet dish (
