RV.Net Open Roads Forum: Fifth-Wheels: Leveling the front jacks (or should you)
 > Leveling the front jacks (or should you)
Dave & Nannette
Burley Idaho
Posted: 06/05/08 10:31am Link  |  Quote  |  Print  |  Notify Moderator
While setting up camp and balancing the sides of the trailer, should the front jacks also be considered for balancing (like by putting a block on one side). Sometimes the site are so unbalanced from front to back that the front sides need to be adjusted differently then the wheels. I have jacks that have holes about an inch and a half apart that a coter pin is inserted, but sometimes when I bring them down, they still are not prefectly adjusted to have the front jacks evenly go down.
Hope I explained it properly and thanks
Dave
U.S. NAVY RETIRED (active duty '72-'93)
'03 FORD F250 POWER STROKE SUPER DUTY TURBO 6.0
'04 KEYSTONE SPRINTER 27' (One Slide out)
1 DOG - SHIH TZU (MOLLY)
Widower; My wife (Nannette) recently passed away, but I'll keep the name "Dave & Nannette"
jdgreen42
Silsbee, TX 77656
Posted: 06/05/08 10:37am Link  |  Quote  |  Print  |  Notify Moderator
The legs on the front jacks should be adjustable. There is a locking pin in them that you pull out and you can adjust each leg individually in order to level the front of the trailer . Some also use blocks for convenience. The pin holes are approx 1 1/2 inch apart so a 3/4 " thick block would let you level it closer. It can be an inch or so unlevel side to side and not hurt anything.
Don
lv2rom
Kansas City, Missouri
Posted: 06/05/08 10:39am Link  |  Quote  |  Print  |  Notify Moderator
They should be pretty close or you are twisting the frame. I use a spacer block under the short side. They do make a screw type of adjustable foot for this purpose, but I like my blocks just fine. I carry three different thicknesses of 3/4 plywood....OK?..Brian
2005 F350 Dually -AFE air/MRSP exhaust/Bags/Bilsteins/Energy Susp.
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs
1996 Layton Fiver 21ft. Totally reconditioned..Love it!!
Fiver-Get-You-Ten
Chattanooga, TN
Posted: 06/05/08 11:11am Link  |  Quote  |  Print  |  Notify Moderator
3 different thicknesses of 3/4 plywood??
2007 DODGE RAM 2500 4x4 QC CTD 5.9 4SPD AUTO RIDE-RITES PRODIGY REESE 16K KWIK-SLIDE*** 2008 MONTANA 3400RL
coptalker
Western Colorado
Posted: 06/05/08 11:57am Link  |  Quote  |  Print  |  Notify Moderator
I had the same puzzling moment...3 thicknesses of 3/4 ply? What I suspect was meant was, 3/4 ply, tacked together into varying thicknesses. But I could be wrong. In the past, I've thought I was wrong but was mistaken.
Glen
2004 Dutchmen 27BG, Rocky Mountain Elk Edition
2002 Chevy Silverado 2500HD 8.1/Ally
2 boys, 12 & 14
a friendly black lab
a couple of decks of cards
a cold beer
Life is too short to sweat the small stuff.
lv2rom
Posted: 06/05/08 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
DAMN...you're good...just as was thinking nobody ever reads anything I post or respond to....thanks for the confidence builder. That should be 3 small (6"X6") pieces of 3/4" plywood.... ...Brian
sbmowrey
DuBois Pa
Posted: 06/05/08 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
If that wasn't clear, the answer is yes you should have them lifting together as they are not designed to lift the front by themself. I also use wood spacer when needed.
2002 GMC 3500 DRW 4x4 8.1/al
1993 40ft Spinnaker 2 slides/3axles
abskws
Pamplin, Virginia
Posted: 06/05/08 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto on the plywood thing but mine are 12" x 12" and I use them for the tires. One piece corrects one bubble off of level.
Allen
Sandy & Shirley
North East, MD
Posted: 06/05/08 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
We carry a couple blocks of 6 x 6 x 12 to use as a base for the landing gear and also a couple pieces of 1/2 inch plywood. Drop the landing gear down to the 6 x 6's, raise them to the first click, then stuff as many 1/2" boards under each side that will fit. When done the most we are off is 1/2 inch.
We also carry a couple 1 foot square pieces of 3/4 inch ply. If we are really on unlevel or soggy ground we put down 2 6 x 6's side by side, then cover them with the 1 foot squares and let the landing gear down in the center of all that.
'02 F350 7.3PSD CC LB DRW, Reese 20K Hitch, Brake Smart, AirLift, C-betr mirrors,
'04 Everest 343L, TrailAir, RotoChoks, Wayne's stabilizer
Toys: Fold-Away Pet Carrier, Thermos Grill 2 GO
For more info, visit Our RV web site.
hotbyte
Barnesville GA
Posted: 06/05/08 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
I have a piece of 1/2 plywood I'll put under the low side leg if needed.
Our Web Albums
For pulling...2005 Chevy 2500HD LT D/A and 1998 Dodge Durango SLT 5.2L
To be pulled...2002 Glastron GX205 and 2005 Pilgrim 276BH-5SS 5'er
