Dave & Nannette
Burley Idaho
While setting up camp and balancing the sides of the trailer, should the front jacks also be considered for balancing (like by putting a block on one side). Sometimes the site are so unbalanced from front to back that the front sides need to be adjusted differently then the wheels. I have jacks that have holes about an inch and a half apart that a coter pin is inserted, but sometimes when I bring them down, they still are not prefectly adjusted to have the front jacks evenly go down.
Hope I explained it properly and thanks
Dave
U.S. NAVY RETIRED (active duty '72-'93)
'03 FORD F250 POWER STROKE SUPER DUTY TURBO 6.0
'04 KEYSTONE SPRINTER 27' (One Slide out)
1 DOG - SHIH TZU (MOLLY)
Widower; My wife (Nannette) recently passed away, but I'll keep the name "Dave & Nannette"
jdgreen42
Silsbee, TX 77656
The legs on the front jacks should be adjustable. There is a locking pin in them that you pull out and you can adjust each leg individually in order to level the front of the trailer . Some also use blocks for convenience. The pin holes are approx 1 1/2 inch apart so a 3/4 " thick block would let you level it closer. It can be an inch or so unlevel side to side and not hurt anything.
Don
lv2rom
Kansas City, Missouri
They should be pretty close or you are twisting the frame. I use a spacer block under the short side. They do make a screw type of adjustable foot for this purpose, but I like my blocks just fine. I carry three different thicknesses of 3/4 plywood....OK?..Brian
2005 F350 Dually -AFE air box/MRSP exhaust/Bags/Bilsteins/Energy Susp./Michleins
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs
1996 Layton Fiver 21ft. Totally reconditioned..Love it!!
Fiver-Get-You-Ten
Chattanooga, TN
lv2rom wrote: I carry three different thicknesses of 3/4 plywood....OK?..Brian 3 different thicknesses of 3/4 plywood??
2007 DODGE RAM 2500 4x4 QC CTD 5.9 4SPD AUTO RIDE-RITES PRODIGY REESE 16K KWIK-SLIDE*** 2008 MONTANA 3400RL
coptalker
Western Colorado
I had the same puzzling moment...3 thicknesses of 3/4 ply? What I suspect was meant was, 3/4 ply, tacked together into varying thicknesses. But I could be wrong. In the past, I've thought I was wrong but was mistaken.
Glen
2004 Dutchmen 27BG, Rocky Mountain Elk Edition
2002 Chevy Silverado 2500HD 8.1/Ally
2 boys, 12 & 14
a friendly black lab
a couple of decks of cards
a cold beer
Life is too short to sweat the small stuff.
lv2rom
Fiver-Get-You-Ten wrote: lv2rom wrote: I carry three different thicknesses of 3/4 plywood....OK?..Brian 3 different thicknesses of 3/4 plywood??
DAMN...you're good...just as was thinking nobody ever reads anything I post or respond to....thanks for the confidence builder. That should be 3 small (6"X6") pieces of 3/4" plywood.... ...Brian
sbmowrey
DuBois Pa
If that wasn't clear, the answer is yes you should have them lifting together as they are not designed to lift the front by themself. I also use wood spacer when needed.
2002 GMC 3500 DRW 4x4 8.1/al
1993 40ft Spinnaker 2 slides/3axles
abskws
Pamplin, Virginia
Ditto on the plywood thing but mine are 12" x 12" and I use them for the tires. One piece corrects one bubble off of level.
Allen
Sandy & Shirley
North East, MD
We carry a couple blocks of 6 x 6 x 12 to use as a base for the landing gear and also a couple pieces of 1/2 inch plywood. Drop the landing gear down to the 6 x 6's, raise them to the first click, then stuff as many 1/2" boards under each side that will fit. When done the most we are off is 1/2 inch.
We also carry a couple 1 foot square pieces of 3/4 inch ply. If we are really on unlevel or soggy ground we put down 2 6 x 6's side by side, then cover them with the 1 foot squares and let the landing gear down in the center of all that.
'02 F350 7.3PSD CC LB DRW, Reese 20K Hitch, Brake Smart, AirLift, C-betr mirrors,
'04 Everest 343L, TrailAir, RotoChoks, Wayne's stabilizer
Toys: Fold-Away Pet Carrier, Thermos Grill 2 GO
For more info, visit Our RV web site.
hotbyte
Barnesville GA
I have a piece of 1/2 plywood I'll put under the low side leg if needed.
Our Web Albums
For pulling...2005 Chevy 2500HD LT D/A and 1998 Dodge Durango SLT 5.2L
To be pulled...2002 Glastron GX205 and 2005 Pilgrim 276BH-5SS 5'er
