RV.Net Open Roads Forum: Fifth-Wheels: Leveling the front jacks (or should you)
 > Leveling the front jacks (or should you)
Ron44
Jarrettsville, MD.
Posted: 06/05/08 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
You level the fiver side to side by driving the fiver tires on wood/plastic blocks.
The front legs should NOT be used to level side to side, ONLY front to back
05 Chevy Silverado 2500HD Duramax EC LB
06 FR Sandpiper 285RG
PD9260 Conv/Charger
16" Alum. wheels
BFG Commercial LT225/75-16E
Trail-Air Equa-Flex
Reese 15K hitch
Prodigy Brake controller
Honda EU3000i geny
Bilstein shocks
Firestone airbags
taxgod4u
Bay Area, CA
Posted: 06/05/08 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
I use a threaded foot from CW that give infinite adj up to about 2 inches. Screw it in for less, out for more.
All things in moderation, except acceleration!
Zip ties, the duct tape of the new milenia!
2001 F250 Powersmoke turbo diesel, 3.73LS
Crew Cab, SRW, SB, 6 inch lift, Single 28 inch semi airhorn underneath! SCMT, A Pillar mounted, Pyro, boost and Trans gauges.
2005 Wildcat 29RLBS, Prodigy, 2 EU2000i's Draw Tite 18K Signature Series, front receiver, on board air, Airlift HD airbags
2003 Ford Explorer XLT 4X4, V8, 5sp AT, 3.73LS
2003 Ford Explorer Eddie Bower 4X4, V8 5sp AT, 3.73LS, Dual semi air horns underneath
2002 XR50, PW50
LadyRVer
Posted: 06/05/08 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Can't help but think, that comment about being one bubble off of level...
Now I know MY problem!
RamTX
Cypress, Tx.
Posted: 06/05/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
I use the polyethylene cutting boards that you get from the Dollar Store or similar store for about $1 each. You can stack them to level the front legs pretty close. They also are easy to keep clean and don't absorb moisture!
2005 Dodge 2500 CTD ShortBed Quad Cab
08 Jayco Eagle Superlite 31.5FBHS
Line X
Superglide Hitch
Prodigy Brake Controller
magster
Palm Bay, Florida
Posted: 06/05/08 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
Think you missed the point here...what happens if the ground is not level and it is not possible to get the legs equally extended. In that case you need something under one leg - or the other...
Cheers,
Magster
2 retirees
2 dogs, 1 cat and a foul-mouthed parrot
2003 29RL Dutchmen Classic, "The Ark"
2001 Dodge 2500 diesel
azjeffh
Chandler, AZ
Posted: 06/05/08 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, that's what I use also. IMO, it's better than carrying shims.
Jeff
Wonderful wife Robin, no children, no pets, no money
05 F250 Supercab SB PSD w/Tow Command
05 HR Savoy 29RKS
JJnLilly
Ohio
Posted: 06/06/08 05:07am Link  |  Quote  |  Print  |  Notify Moderator
I carry several pieces of plywood of various thicknesses to put under the short leg. Though I can not always get them perfectly equal, they are close so that the unit rises nearly equal and avoids putting stress on the jacks and torque to the frame.
2007 Ram 2500 QC CTD
2004 Cougar 290RK
Ron44
Jarrettsville, MD.
Posted: 06/06/08 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Cheers,
yep, seems maybe my bubble was out.. LOL.
I use 1 1/2" blocks with a couple 1/2" blocks to adjust front legs so the legs hit evenly as I lower them
lawrence617
High Point, NC
Posted: 06/06/08 05:52am Link  |  Quote  |  Print  |  Notify Moderator
I am used to a level lot, but the lot that I plan to park on has some side slope. Need advice on how and what to use to push the fiver on the wood, should I get a small ramp and stack wood behind the the ramp or place wood in stair like fashion or should I get a hydraulic jack, jack up the fiver, and slide wood underneath the wheels? Any suggestions or advice would be great.
2006 GMC 4x4 2500HD Duramax/Allison Crewcab Shortbed
Roadmaster Active Suspension
Voyager Braking Kit
15K Reese Slider Hitch
2008 Jayco Eagle 345BHS
vonzoog
Delaware
Posted: 06/06/08 06:15am Link  |  Quote  |  Print  |  Notify Moderator
Lawrence,
Here is what I do and you can use this as a starting point and modify to suit you needs.
I have two pieces of 2x8s. The short one is about 6 inches longer than the distance between the axle hubs. The longer board is about 12 inches longer than the short board. I then cut a 45 degree angle on one end of each board. This gives a little help for the tires to roll up on. Depending on how much I am off level, I use one or both board. I have never needed more than two baords, yet. This is also a very cheap way to do it. If you want to pay for the plastic stackable pieces you made do that instead.
I pull into the lot and stop the 5ver where I want it and check to see if I am level. If not, I place one or both boards (this depends on how off level you are) in position next to the tires. I then pull forward until my spotter (wife) tells me to stop when I have cleared the board(s). She then slides the board(s) into position directly behind the two tires that I will be lifting to level the 5ver. I then back up onto the board(s) until she tells me to stop. Then place my wheel chocks. You do not have to jack up the 5ver in any way this only takes about 30 seconds to accomplish.
Hope this makes sense and helps you out.
If you have to ask why I drive a Diesel, then you will never understand.
2004 RAM 2500 SLT Quad Cab 4x4
Cummins(305/355) 48RE Auto 11.5 Rear
2004 Laredo 29GR
