RV.Net Open Roads Forum: Truck Campers: Propane-in-the-butt Generac
 > Propane-in-the-butt Generac
Fat Fox
Issaquah, WA, USA
Posted: 06/05/08 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
My Generac propane generator has always been a temperamental SOB but from time to time it would run for a while and then just shut off. Last night I fired it up after dewinterizing everything and it ran for about 4 minutes before shutting off again....then I started it back up and it ran for 2 minutes before shutting off....then 1 minute. Now it won't remain running for more than a 20 seconds or so before it shuts off. I have a new tank of propane & everything else works fine on the camper.
It is extremely difficult to see anything in such a confined space, but it appears the solenoid that turns on and lets the gas flow is shutting off. If I hold the inlet propane pipe I can feel the solenoid click off right before the engine dies. But I don't know if it is happening because it is messed up or if something else is messed up or there is some danger condition it is reacting to that I can't see. Unfortunately, I can only do limited diagnosis unless I take it out of the camper.....which is a full day's job with this Fox camper.
So, I'm wondering if anyone else has had this issue?
- Chris
Chris S.
03 Arctic Fox 11.5
01 F350 supercab Powerstroke Diesel dually 4X4
Rancho 9000, Firestone air bags, Roadmaster sway bar
Torklift/Fastguns, Lance cabover struts, Aquajet variable speed H2O pump,(un)Happijack electric jacks, Homemade jack stabilizers
stickyeye
New Jersey
Posted: 06/05/08 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a low oil cutoff?
1150 AF Truck Camper, gen-set, pretty well loaded
Torklifts, superhitch w/48" extension, firestone air bags, energy suspension bump stops, fast guns
2005 Ram Quad Cab 3500 Dually. CTD, auto, 4.10's
CISCO8325
Peoria,az.
Posted: 06/05/08 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
you may be gettin air from somewhere. turn you stove burners on and bleed (make sure you lite them up) them to see if they don't turn off.
trander
Pueblo, Colorado
Posted: 06/05/08 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have had two problems similar to this. It sounds like it is shutting down after the delay period is up and the gen picks up the ac load. If I move the wiring around on the left side of the gen it will then be ok, probably a loose connection in the 12 pin plug on the cable to the invertor. Or the propane supply hose was kinked and causing the same type of problem. I rerouted the hose to fix that problem. I have a new cable ready to replace the one to the invertor when it finally fails. Try turning off the main breaker and see if it continues to run, if so it is that piece of junk 12 pin cable.
* This post was edited 06/05/08 08:53pm by an administrator/moderator *
Hey there
Pendergrass, GA
Posted: 06/05/08 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds like it is timimg out because of the "no oil" sensor or the "low oil pressure" sensor activating.
Kurt
2001 Silverado 3500 DRW CC LB 6.0
1993 Lance Squire Lite 150 (8'6")
2001 Fleetwood Caribou 11J (11'6")
