RV.Net Open Roads Forum: Fifth-Wheels: Water Pump running But Pumps no Water
 > Water Pump running But Pumps no Water
augustpilot
Sun City, Texas
Posted: 06/05/08 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
New Eagle Fvr with Shurflo pump, worked ok for 1 month. Last nite was awakened to hear pump running, no water coming out. Sounding different like it was cavatating, had no water. Turned swith off. This morning moved all the valves underneath in storage area, turned the swith on and off in storage area, finally got it to work with the old noise it made and water did come out. Great, but now tonite it has messed up again doing same thing. I am not in convenient place to run 75 miles to a dealer to ck it, it is under warr. I may go to camping world and buy new pump, but would like to know if anyone with the water pump has had this experience. Help and thanks.
2008 Jayco Eagle 313 Fifth Wheel, 2006 F-250 Ford 6.0 Diesel, 3.73, 4dr, Pullrite super glide hitch, One Co-Pilot
sele
illinois
Posted: 06/05/08 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Once there was a screen plugged at the inlet side of the pump, after disconnecting the inlet water line it was either a quater or half a turn and the end came off. I cleaned the screen and we were back in business. Hope this helps.
scott
Gadget Guy
Whitefish/Calgary
Posted: 06/05/08 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
No need to buy a pump. It will be a restricted inlet screen or a leak on the suction side of the pump. The leak can be very small to cause you problems like this. I once had the filter crack by tighting it to much. Looking at it you could not see a crack but with a magnifying glass you could just barely make out the crack. Replaced it and the pump worked great. Also check all the fittings on the suction side of the pump. Good luck
KSadler1
Albuquerque, NM
Posted: 06/05/08 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
I remember someone saying something about having to "prime their pump" a while back. I forget how it's done but that's the first thing I'd try. I'm sure someone will remind us how to do it though.....
Ken
TnTtravelers
East Slope Sierra, California, USA
Posted: 06/05/08 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
See if you can access the water pump itself and check the water connections on the inlet side of the pump. When my coach was new, I accessed the pump in the basement and found loose connections and had a water leak. Easy enough to fix by just snugging up a couple of loose fittings.
If you have a leak at the inlet side, the pump would be sucking in air, which could cause it to loose the prime.
Don't overtighten though.
good Luck
Tim and Tina (kudo too)
Livin' good, while the livin's good!
2005 Ford F350, 4x4, Crew Cab, Short box
2007 Everest 295TS 5th Wheel (Superglide hitch)
JT Stabilizers
lv2rom
Kansas City, Missouri
Posted: 06/06/08 12:29am Link  |  Quote  |  Print  |  Notify Moderator
Yep, I vote for a loose connection on sump side, it won't necessarily show up as a water leak (sump only, no pressure), but will allow air into the line, and the pump keeps loosing its prime....Brian
2005 F350 Dually -AFE air box/MRSP exhaust/Bags/Bilsteins/Energy Susp./Michleins
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs
1996 Layton Fiver 21ft. Totally reconditioned..Love it!!
Vulcanmars
Naples, FL
Posted: 06/06/08 07:52am Link  |  Quote  |  Print  |  Notify Moderator
My new to me Rage'n has a broken check valve in the "city water" connection. I almost went nuts looking for a leak.( I could hear running water; I thought it must be filling the walls or basement: It was shooting out of the water connection onto my truck that was parked next to the 5er.) It's funny now.....
Mars
06 Rage'n FA3005
04 V10 F250 SDCC 4X4
Pullrite SG 16K
1st TH 02 Keystone Tailgator
USA in a Chevrolet
Manahawkin, New Jersey
Posted: 06/06/08 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Sometimes, it is the pump. At least, that's what happened to me. I started having problems when I was winterizing. I could not get the pump to suck the antifreeze into the pump. After holding the gallon of antifreeze higher than the pump, it worked. Then on a trip I had the problem of the pump cavitating & not pumping water. I changed the check valve on the water inlet, pulled down the insulation under the fresh water tank and checked the connections there & checked all connections on the pump. All looked good. I replaced the shurflow pump with a brand new one of the same make & model & have had no problems since. So, in my case, it was a bad pump. It was a lot of work checking the connections (taking down the insulation under fresh water tank alone took an hour). I would have been better spending the $74 for a new pump. But if it happens again, I'll probably go through the whole process of checking all connections. Just makes sense to check everything out.
