8iron
Canada
I read a post here recently regarding transfering gray water to the black tank. Do a search and this might help.
Martyn
Bennett, Colorado, USA
mbopp wrote: I take 1 or 2 5-gallon buckets with lids & pour spouts with me. I'll off-load the gray water with a garden hose cap adapter & short hose then dump them at the dump station. The buckets were freebies from the tire shop I used to work at - they're what the bead lube comes in.
This is what I do too.
2004.5 Dodge Ram 2500 QC CTD 4x4 SLT; 2007 Coachmen Chaparral 267RLS;
Reese 15K Slider;Prodigy;JT Stabilizers;2 Honda EU2000i's;
2006 Glastron MX175;
rv-forums
2005 Dodge Magnum for the DW
cwsoules
Columbia, SC
Why tow a bathroom and not use it? At least you know how clean it is. We do not use the CG facilities. I have an 11 gallon rolling tote and it fits our needs well. A bigger one when full would be too much work to tow by hand. Our rig has two 40 gal gray tanks one bath and one kitchen so we are not strapped to dump very often.
USN RET. 2001 Diesel Dodge Quad Cab 2500 Auto w/4:10 rear end. Miller Mfg Truck Bed Cover, with RBW hitch, and a 1995 29' Automate 5th wheel with one slide
rockhillmanor
On the Road
8iron wrote: I read a post here recently regarding transfering gray water to the black tank. Do a search and this might help.
There is one couple on the forum that had a pretty nifty set up where they had a manually switched pump they installed to pump gray into the black when needed. They emailed me the specs on it for a friend of mine, I'll see if I can find it.
Me....all I have to do is take a shower....that drain goes into my black tank.  :
31 ft Four Winds
Chevy Tracker 4x4 BlueOx Aventa LX
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
tenbear
Northern Vermont, USA
We do our dishes in a plastic basin and dump the water down the toilet when we don't have a sewer connection. That will help some since the black tank always fills up slower than the grey.
2004/5 Four Winds Dutchman Express 28A, Chevy chassis
Subaru Impreza Outback
PattieAM
Maryland
You've got a few choices:
First - use less water (wet down, turn off shower, lather up, rinse off) or use the campground's showers. Do dishes once a day and maybe use a dishpan and empty in the woods or shower house vs. filling your tank.
Or you can get a tote for your greywater and empty your holding tank frequently.
There are 5 gallon water totes you could use, or buckets - whatever would work best for you.
flathead92
Chandler AZ
Bite the bullet and by a external tank. Otherwise you will become lazy and like other lazy and cheap people you will just open the tank and let it drain out gross.
mooneyes
wisconsin
I have a portable tank no big to drag it over and dump with TV my problem now is how to transport the tank from place to place I am not going to hang that thing from the back of the trailer.So I am still in need of a fix!.
CSpenceFLY
Macon,Ga
Check under your unit. You might be able to put it between the frame rails.
"You're lucky to be alive my friend."
Quote from the "Do it yourself police" and many others that have known me.
Lantley
Ellicott City, Maryland
mooneyes wrote: I have a portable tank no big to drag it over and dump with TV my problem now is how to transport the tank from place to place I am not going to hang that thing from the back of the trailer. So I am still in need of a fix!.
Hey I resemble that remark!
01 PSD X,06 Trailvision 31BHDS Edge Evolution
4"exhaust,AFE,C-Betr,Tornado
Firestone air bags,TomTom,Atwood 3500
Hensley,Prodigy,exhaust brake,Swift Hitch
14'PortaBote9.9hp,6"PVC,Thule,Combi-Cam
Toppoprails,Bodiak,Sherline,Maxx Air
Subaru 4300is w/Gen Box
