RV.Net Open Roads Forum: Tech Issues: auqamagic IV toliet
 > auqamagic IV toliet
graydog1
Iowa
Posted: 06/06/08 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone else had a problem with the new ball system instead of the flap they used to have. I am having problems with it not closing all the way.
08f450psd
Westminster, Maryland
Posted: 06/06/08 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
I have to put some olive oil in my bowl every now and then to keep it lubricated, but that's only issue I've had.
What makes you think it's not closing all the way ? Water leaking out ? Or you actually see day-light (so to speak) ?
SCR
Full Timer - I'm really not sure where I am
Posted: 06/06/08 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
Yes I have, more then I would like.
I found that letting the flush pedal snap back with more force rather then letting it return more gently helps. Your spring cartridge may require lubrication or may have become weak requiring replacement. Be sure the gaskets are clean and properly maintained.
