RV.Net Open Roads Forum: Travel Trailers: A/C -water dripping down our awning
 > A/C -water dripping down our awning
mollee
canada
Posted: 06/07/08 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Hi everyone!
On Friday we had the pleasure of finally having a hot enough day to require turning on the A/C unit (15000) of our Jayco 31 RKS. We've already experienced enough of the furnace! It was very hot and humid that day. After the air was on for a while we noticed water dripping down our awning. Is this normal or should we be looking for something? Shouldn't there be a drain of some kind like in a window A/c unit on a house instead of just running out of the A/C and on to the roof?
Well I hope everyone is enjoying the hot weather. I figure I can start to complain about the heat and humidity any day now!!!!But...at least now I can complain from my TT!!
Happy camping everyone!
Mollee
rjsurfer
North Carolina
Posted: 06/07/08 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Water coming off the roof is normal on RV's, don't sweat it.
Ron W.
03 Dodge 2500 SRW,SB,EC
2008 Keystone Cougar 245RKS 5th Wheel
DRZ-400SM
DL-650
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 06/07/08 11:12am Link  |  Quote  |  Print  |  Notify Moderator
It just runs onto the roof, then if your rig is leveled right, drips down a gutter spout! So level your rig to allow it to go the other way.
mhardin
Texas!
Posted: 06/07/08 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Or, perhaps your gutter is clogged causing the water to take a different path.
lostmarbles
Sacramento, CA., USA
Posted: 06/07/08 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
OR! Make a diverter by measuring the awning width and putting a 1/2" X 1/2" piece of wood, plastic, something with goop (clean roof area first), to offset that area of draining if everthing else is o.k. Then paint it white like the roof if it's the case...
campinginthewoods
Rantoul,IL
Posted: 06/07/08 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Well you could always turn off the A/C......
"It Bears all Things,Believs all Things, Hopes all Things,Endures all things......Love never Fails...."
Hornet28BHDS
Parker, PA
Posted: 06/07/08 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
That's perfectly normal. You enjoy the hot weather, I sure am!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
2oldman
WA
Posted: 06/07/08 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Run a bead of caulk on the roof where the water wants to go, and direct it elsewhere.
davidj54
South Alabama
Posted: 06/07/08 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
As said before, it's perfectly normal. I always set up just slightly off level.
About 1/2" low to the off side and toward the back. That way the condensate drains off the back corner. This practice eliminates the need for trying to divert the water by attaching things to the roof.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
mhardin
Texas!
Posted: 06/07/08 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Dat be what I do, too. However, check the gutters, they do get clogged. Then, if they are clear, just adjust the level slightly and that will fix it. Like Davidj54 said, there should be no need to attach anything to the roof.
