RV.Net Open Roads Forum: Norcold fridge giving me a "NO FL" message
 > Norcold fridge giving me a "NO FL" message
Branman1971
Pasadena, MD
Posted: 06/07/08 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
When I unplug the rig from shore power, and the fridge is set to AUTO, it should switch to LP for the fridge. Well, I guess it's not doing so. A small audible alarm goes off and it says NO FL...Not sure what that means. My LP tank is full. When I start the generator it works fine too. Any ideas anyone?
03 Bounder 37U DP, 06 Silverado 4WD, 96 Camry(Toad), 03 Harley Davidson NightTrain FXSTB, 1 Hunee of a Wife, 3 kids(9&17&20), and 3 Puggles (Laverne, Shirley, and Squiggy)
heavyequiptmentmover
Huntington Station ,New York
Posted: 06/07/08 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Is there 12 VDC to the control panel,at rear of refer,when you disconnect shore power.Need 12 VDC when operating with LP gas.
When you start the genset you have an alternate source of 12 VDC from the converter/battery charger.
Branman1971
Pasadena, MD
Posted: 06/07/08 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
I will check that, thanks...I looked at the Norcold website, and I think the code I am getting might mean "no flame". So maybe I will try both of those avenues.
MELM
GA
Posted: 06/07/08 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Which model?
Good Samaritan
Ohio
Posted: 06/07/08 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
You have the needed 12VDC or the refrigrator would not be on.Norcolds priority scheme is to always look for AC first when in the Auto mode. If you take away the AC input to the refrigerator the controls will recognize this and automatically switch to the Auto LP (gas) mode. While in the Auto LP mode the igniter output is energized for approximately 30 seconds. If after 30 seconds a flame is not detected the contol will give you an error message. In this case because it is in the Auto mode and the control did not sense an AC input or a flame the error would be NO AC (no AC input detected) followed by NO FL (no flame detected). If you are just getting a NO FL error you apparently are operating in the Manual LP mode? In the manual LP mode the operation is similar in that the igniter output is energized for 30 seconds at which time if the control does not detect a flame (doen't mean there can't actually be a flame present, it just means the control is not detecting it) the NO FL error is registered. Check to see if you are getting a flame or not. Also, like someone else mentioned it would be nice to know what model/vintage refrigerator we're talking about.
JFG
TN
Posted: 06/08/08 09:28am Link  |  Quote  |  Print  |  Notify Moderator
Check the dc fuse for your refer.
Fred
Possumpoint
Virginia, USA
Posted: 06/08/08 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Had this happen to me this weekend. Opened up the refrigerator outside cover and could see that there was a flame and could also hear the buzzing of the igniter. After thirty seconds I got the No Fl display and a soft beeping.
Opened up the burner box and there was a piece of rust scale that had fallen down the chimney and was blocking the flame from hitting the heat sensor. Removed the scale and the refrigerator worked fine. When I get home I'll need to clean out the burner box.
2006 30MH24SL Bigfoot Class C
2003 Citation 32' Sky Deck TT
2003 Artic Fox #1140
Rick & Kathy, My best friend and wife for 38yrs
Pepe, Rascal & Peewee(our furry children)
