RV.Net Open Roads Forum: Tow Vehicles: Trucks with two batteries
Search only in Tow Vehicles
 > Trucks with two batteries
5er4ever
Ontario Canada
Posted: 06/08/08 07:32am Link  |  Quote  |  Print  |  Notify Moderator
I do not need a second battery for my truck I need a convenient place to store my boat battery and have it re-charged. How more convenient than in my truck!
Researched solar panels (with RV site guy's having experience - just won't keep up) my fishing demands are greater than reasonable solar delivery.
So - just a thought........ how and where does the 2nd batter option fit into a truck?
never seen a truck with two but know they exist.
a Post Employment Recreation and Leisure Specialist that believes "The best part of doing nothing is resting up afterwards!".
Scarface56
Appleton, Wisconsin
Posted: 06/08/08 08:00am Link  |  Quote  |  Print  |  Notify Moderator
You didn't say what type truck you have? I have a 2008 GMC3500 with dual batteries and a 1996 2500 with dual batteries. They have kits to install another battery including the isolation switch and battery box.
I also have dual batteries in my boat that are charged by the boat motor, plus two more batteries for the electric trolling motor with a plug in charger.
Just Me & DW
2008 GMC 3500 SLT DRW Diesel
Pioneer AVIC D3 GPS Nav/Stereo/backup camera
2007 276RLS Cougar 5th wheel by Keystone
Scooter Buddy 125
17.5 Crestliner Boat
For those of us who fought for it, freedom has a flavor the protected will never know.
SCR
Full Timer - I'm really not sure where I am
Posted: 06/08/08 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I think all diesel trucks have two batteries
5er4ever
Ontario Canada
Posted: 06/08/08 09:09am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2001 GMC SierraC3. Kinda unique AWD truck. In between GMC name changes from 2500 to 1500hd but was the prototype for the Sierra Denali (believed to have only 4200 built). I would have to install a kit. Just starting research now on possibility of where, what, how and where the battery goes?
Thanks for the reply.
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/08/08 09:38am Link  |  Quote  |  Print  |  Notify Moderator
On my '92 F350 with gas engine, the truck did not come with factory dual batteries, but the diesels did. The problem for me was the spot were the second battery normally goes on a diesel was taken up by my air box and window washer & radiator overlflow reservior tanks. I didn't want to spend the money buying all the factory parts for a diesel to fit the battery in that location, since I would have needed new reservior tanks and air box in addition to the battery tray. So what I did was remove the factory single battery tray, move an air cannister over a bit on the fenderwell for the smog system (still connected) and had just enough room to fit two Optima red-top gell-cell batteries together in the normal single battery location. Works great.
I welded up a tray to hold both batteries from angle steel and made a hold-down bracket for them too. I have them wired in parallel with no isolator, charging as one 12v battery. I get plenty of cold starting power and twice the reserve minutes and the Optima batteries are very powerful for their small size. The Optimas are expensive, but worth it, and they handle off-road abuse great (have run them in my Bronco, buggie and other 4x4's used for off-road fun.
pic
pic
* This post was edited 06/08/08 11:19pm by SoCalDesertRider *
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
dougger222
Maplewood MN
Posted: 06/08/08 10:03am Link  |  Quote  |  Print  |  Notify Moderator
The three diesels have batteries on each side of the engine compartment.
2000 Excursion limited 4x4 PSD
1999 F350 lariat crew cab 4x4 DRW PSD
1999 F250 xlt 4x4 x-cab PSD
1965 Mustang 289 auto
1969 GTO 400 4sp
1986 GLHS Shelby
1999 Neon R/T
04 PJ 15K dump trailer, 04 H&H 20ft 9K tilt bed
cewillis
Tucson, az, usa
Posted: 06/08/08 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
and wired together (at least mine is).
dixoncider
socal
Posted: 06/08/08 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
To do it right I think you need the battery Isolator. find a place for the boat battery and run the wires from the isolator.
94 Ram 2500 Diesel
06 Ram 3500 Mega CTD Jake Brake
07 Pioneer 26BHS
RollingRockTX
Keller, Texas
Posted: 06/08/08 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
Don't need two bats? Hmmm interesting. Why do you not want to start your truck? Saving on ULSD?
You "could start your truck with one bat for a time however you could end up doing more damange to your truck by making it harder to start.
2006 Ford F250 King Ranch PSD
2008 Jayco Eagle Super Light 31.5BHDS, KC5PFG,
5th Airborne with SideWinder, Plugitright Stabilizers.
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/08/08 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
Our E350 diesel van has the 2 batteries mounted on the outside of the right frame rail below the body between the passenger door and the rear wheel, as there is no room at all in the engine compartment for a battery. That spot is usually open on most pickups for an extra battery to be mounted there, or it can be mounted in the bed.
