RV.Net Open Roads Forum: Tech Issues: ELECTRICAL PROBLEM
 > ELECTRICAL PROBLEM
Rhinojoe
Inland Empire
Posted: 06/12/08 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Found the following in Honda specs;
"Automatically switches off if there is a short circuit or significant overload"
There's where I'd first look. Probably overloading the gen-set.
sirdrakejr
Las Vegas, Nevada
Posted: 06/12/08 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from 5th wheels to tech issues.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
hwrd_shnnn
kentucky
Posted: 06/12/08 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
The gen set will not idol down if it is hooked up to the power cord, it has a constant pull on it from the rv's inverter. As for the over loading it should not be unless the ac is on or trying to run.
RJsfishin
Winston Or.
Posted: 06/13/08 07:23am Link  |  Quote  |  Print  |  Notify Moderator
Some think that the Honda 2000 will run everything except the A/C....wrong !!
It won't even run the microwave,...if the batteries are dead ! (60 amp conv)
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
