RV.Net Open Roads Forum: Class A Motorhomes: Accidentally filled gasoline in diesel tank
 > Accidentally filled gasoline in diesel tank
Page of 8
Golden_HVAC
Fulltime, CA, USA
Posted: 06/09/08 10:50pm Link  |  Print  |  Notify Moderator
They send gasoline and diesel down the same pipeline - it gets mixed all the time. Winter diesel fuel is basically unleaded fuel and diesel mixed.
As for adding 2 cycle oil, I would not put that into a 2005 or newer diesel engine.
The recomendation to add a fuel additive that will increase the lubrisity, that miht be a good idea.
Remember that unleaded fuel and diesel come out of the same distiller - just at differant boiling points.
Mercedes allows a certain amount of unleaded fuel to be added to a diesel tank and be considered accptable to use.
I would think that Cummins might say that 5% - 10% is acceptable, and I think you said that the whole 5 gallons did not go into the tank.
Fred.
2oldman
Moses Lake
Posted: 06/09/08 10:54pm Link  |  Print  |  Notify Moderator
Unleaded? It's all unleaded.
Charlie D.
Golden Triangle-E. Texas
Posted: 06/09/08 11:13pm Link  |  Print  |  Notify Moderator
Bear461 wrote:
My neighbor is a diesel mechanic - I accidentally put about seven gallons of gasoline into my 35 gallon diesel tank on my Dodge. He advised to add a bottle of Lucas fuel injector cleaner and then drive the vehicle. When I got down to three quarters of a tank to top it off. I did this twice and never noticed any difference in the way the vehicle has run. At the time I made my mistake, the engine had about 5000 miles. It now has over 50000 miles and it runs like a top - consistently averaging over 10 mpg towing a 15,000 lb. fifth wheel. Don't sweat that small amount of gasoline!
I added 3 gallons of gas to my 26 gallon tank before I realozed what I was doing. Called a diesel mechanic. He said to add 1 quart of transmission oil and 1/2 quart of Diesel-Kleen and I would be O.K.- Drove 200 miles the next day, filled up after 100 miles. Driven/pulled 20,000 miles since with no issue. I have learned to be more careful now. Scared the pants right off me.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
stevelv
Living on the island
Posted: 06/10/08 01:00am Link  |  Print  |  Notify Moderator
An experts advice
Personally I'd just drive it.
RV Park Finder
Ex Fulltimers
Restored a 1984 Monaco Regent - now with new owner
DH,DW,Jake and Indie
MasterBoondocker
nw lower Meeeechigan, TN and FL
Posted: 06/10/08 02:49am Link  |  Print  |  Notify Moderator
tom_kat wrote:
5 gallons to 95 gallons should not hurt it,we had a driver that would add about 5 gallons to each 55 gallon tank for more power but it did do engine damage after a lot of miles around 150,000 but he did it on every trip not a one time mistake thing.
My Dodge Cummins 24v LIKED a lower cetane rated fuel. I was in Eastern TN some years back and a station there had 2 selections of diesel .. and I picked the lower rating... just to try-it-out. I picked up at least 2 mpg ...and the truck performed better.
JUST LIKE in a regular gas vehicle ... if you use toooo HIGH of octane fuel ,...it will cost you both in performance and MPG.
Does anyone have a formula on lowering the cetane? ..
AZPops
Wherever the Job takes us...
Posted: 06/10/08 04:20am Link  |  Print  |  Notify Moderator
in2dp4u,
Thank you for the link, this is an article I am definitely keeping for future reference.
After reading this article, although diluted, I personally would not do anything till I contacted Cummins (always good to be safe then sorry).
LUeno
* This post was edited 06/10/08 04:31am by an administrator/moderator *
Executive
Posted: 06/10/08 06:49am Link  |  Print  |  Notify Moderator
When do you suppose that article was written..???/.......call Cummins..JMO
Dennis and Debi
Chevy HHR W/ ReadyBrute
Full Timing and Living the Dream
Hyall
Davie, Florida
Posted: 06/10/08 06:59am Link  |  Print  |  Notify Moderator
Loan YOUR RV to ever! as for the mixture so lo in percentage you shouldn't have any problems same as my service trucks at times we get a drivers adding gas by mistake catch it my several gallons and stop we just drive it off.
2007 Gulfstream TourMaster T40B MBE 926
2007 Honda CR-V
MC Honda VTX 1300R grey is faster
MC Shadow Aero 750 wife's
DON'T WORRY ABOUT NOTTIN - NOTTIN IS ALRIGHT
daverich
Lebanon, MO until April 7 then to St. Joseph, MO
Also call your insurance claims people and see if this is covered.
Sounds weird, but it is worth the call.
Turbo Diesel Dude
Green Mountain, NC
Posted: 06/10/08 07:07am Link  |  Print  |  Notify Moderator
I did that in New Hampshire once. Put 5 gals in on top of about 7-8 gals od diesel before I caught it. I just put two qts of 30 wt oil in it and drove it until most of it was gone, Had plenty of power, but stsrted a little hard. That was about 50K miles ago. No sweat, drive it like you stole it.Didn't hurt a thing. Cummins are pretty tough. JMHO
charles weidman
Page of 8
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
