RV.Net Open Roads Forum: Beginning RVing: Do these really work? Fridgecool
 > Do these really work? Fridgecool
jlvtx1800
Buffalo
Posted: 06/10/08 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Not sure where to post this and it is probably a newbie question so I figured I would try here. I noticed that our fridge does not keep up very well when being used (opening and closing during meal prep) and was hoping to find something that could help. Thanks
FridgeCool
or
Fan vent
- 2008 Ram Laramie MC 4x4 SRW 3500 CTD 6.7L 6 speed manual
- 2008 Jayco Eagle 345 BHS
rockhillmanor
On the Road
Posted: 06/10/08 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Nothing really helps these small fridge's when you constantly open and close the door. Getting in the habit of closing it 'right' away is the key.
You can't leave it open and 'slowly' take out all the stuff you need to make dinner. Get in and out as fast as you can!
Buy yourself the small battery operated fan from camping world, they work for help keeping the temps the same top and bottom, which it the real problem with RV fridge's.
I put mine on the bottom of the fridge and it does help.
* This post was edited 06/10/08 11:22am by rockhillmanor *
31 ft Four Winds
Chevy Tracker 4x4 BlueOx Aventa LX
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
Martyn
Bennett, Colorado, USA
Posted: 06/10/08 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Yes they do. A very good accessory to have. RV fridges operate best with air freely circulating. These fans help that a lot, and can increase the effciency of the unit considerably.
2004.5 Dodge Ram 2500 QC CTD 4x4 SLT; 2007 Coachmen Chaparral 267RLS;
Reese 15K Slider;Prodigy;JT Stabilizers;2 Honda EU2000i's;
2006 Glastron MX175;
rv-forums
2005 Dodge Magnum for the DW
Beacher
Long Beach, CA
Posted: 06/10/08 11:20am Link  |  Quote  |  Print  |  Notify Moderator
I too use the FridgeCool battery powered fan. When I first purchased my RV, I noticed that the refrigerator had cold spots, and REALLY cold spots, (where stuff would freeze). Since using the fan I have not had to experience the surprise of frozen milk, and beverages. It works for me.
The fan vent that mounts to the exterior is good for summer, and hot weather camping. It helps increase the efficiency of the refrigerator by increasing the air circulatiing over the cooling fins behind the refrigerator. If you have ever experienced your refrigerator struggling to keep things cold, then one of those would help. I was going to install the solar-cell version on mine.
tom_kat
way upstate new york/lake george area
Posted: 06/10/08 11:43am Link  |  Quote  |  Print  |  Notify Moderator
made one with a 12 volt computer fan mounted under the cooling fins inside the refer at the back made a big differance in cooling.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
Bearnkat
Fort Worth, Texas
Yep, I have a fan on the inside of our refrigerator and also the one you linked to for the outside. Yep, they both do a good job keeping the refrigerator's temperature at an acceptable level. I recommend both of the products.
Chuck & Terry
2005 Pilgrim 281RB-S
2006 Ford F250 Lariat CC 4x2 PSD
My Lap-Band Journey!
DFW/Central Texas Rally - Fall 2008
Chuck and Terry's Pilgrim Adventures
North Texas Camping Association
Lone Star Dutch Oven Society
Pawz4me
North Carolina
Posted: 06/10/08 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
I use the FridgeCool fan and I do believe it helps. Even on the hottest days, our fridge will cool off very well within twelve hours with the little fan running (whereas others have posted that it takes their fridges 24-48 hours to cool off). We've never had any problem with it maintaining temps while camping, regardless of how often the door is opened (however, I do try to stress to the family to not just stand there with the door open taking their sweet time). The batteries seem to last a very long time, too.
Me and the DH
Two boys and two dogs (and two cats who prefer to stay home)
2008 Forest River Georgetown 350DS (bunkhouse model)
2001 Honda CR-V
jlvtx1800
Buffalo
Posted: 06/10/08 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone...This rving stuff is definitely turning into a money pit!!!
enblethen
Moses Lake, WA USA
Posted: 06/10/08 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
The fans do help.
A small 12 volt computer fan blowing or cooling unit is a less expensive way.
Another cheap item to improve efficiency is to restrict the distance between the cooling unit and the exterior wall of rig.
I got some scrap foam board insulation from my local lumber yard. Used Liquid nails to install on exterior wall. "Rvmobile.com" has good description of what is best for ventilation. This did more then the fan.
Bud
Suzuki XL7 pushing Pace Arrow
LarryJM
NoVa
Posted: 06/10/08 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
FridgeCool
or
Fan vent
Along with the small battery frig/fan I also made and installed a DC brushless computer cooling fan that clamps to the refer fins and has a switch and is removable. I found when the frig is fairly full this really helps in getting the air moving inside the frig to even out the temps inside.
This shows the fan mounted to the fins of the refer. It's basically to pieces of al. flat stock that grab the fin. I can also move the fan around on the fans depending on where I want it.
This shows the fan front where I put wire mesh to protect the blades and shows the power plug and jack that makes it removable when not needed along with on/off light switch. This is a 12V DC brushless fan from a computer
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
