RV.Net Open Roads Forum: Fifth-Wheels: Towing with a long bed truck ???
 > Towing with a long bed truck ???
egandlg
South Dakota
Posted: 06/10/08 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2005 GMC Extra Cab 3500 dual wheel Duramax. We are thinking about purchasing a 2005 Heartland Landmark 5th wheel which is designed to tow with a short bed truck. Is there a problem if we tow it with a long bed truck? I measured a long bed and a short bed and the distance from the tail gates to the middle of the rear axel is almost the same. The difference in length between a short & long is in front of the rear axle not behind it. Am I correct in assuming the Landmark 5th wheel can be towed with no problem at all with a long bed truck? Thanks
MARKW8
Akron OH
Posted: 06/10/08 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
You won't have any problem. Heartland builds thier trailers with extra cab clearence for short beds. With your long bed you'll yust have that much more room.Mark.
randy&shereen
Jackson, MI
Posted: 06/10/08 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
LONG BOX can pull ANY 5th wheel design. (notice I stated "Design", not weight) Lots of room for bikes, generator,tool box, wood, etc. Many manufactures have designed "Short Box" friendly designs as over 1/2 of the truck market is short boxes. Short box owners need to be aware of design features or purchase a slider hitch. Randy
2004 GMC Sierra 2500HD SLT CREW CAB LONG BOX (7380#)
8.1 Big block Gas/Allison 4:10 4x4
2004 Newmar Kountry Star 34 BLWB 3 Slides (15620#)
Pin Wt 2560# (16.3%) Total combination Wt=23,000#
sirdrakejr
Las Vegas, Nevada
Posted: 06/10/08 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
I prefer the long bed truck since the fulcrum for movement is better in the longer bed. That means the trailer wont whip it around so much especially in windy conditions. You will be fine.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
fncampn
Gardnerville, NV
Posted: 06/10/08 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
I've towed 5th wheels with both long and short beds and prefer the extra stability of the long bed. You will have no issues with that 5th wheel, especially with a dually long bed. That's a nice 5th wheel BTW.
Cold Weather Camping Mods
How to Do Just About Everything in an RV
'08 Ford F150KR Screw 5.4L LB Auto 3.73LS 4x4
'07 Ford F350 XLT CC LB PSD Auto 3.73 4x4 - SOLD
'08 Thor Summit 27RBS TT - 9000 GVWR, 7500 loaded, 875 TW
'06 Kipor 3500Ti Generator
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/10/08 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
LOL. Never thought I'd hear the day when someone would ask if a longbed can tow something! Of course it can!
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
RedRam
Moved from the smallest county in Texas
Posted: 06/11/08 08:54am Link  |  Quote  |  Print  |  Notify Moderator
I like the room in my longbed and never owned a shortbed but if you ever want to install a fuel tank or carry cargo then a shortbed might be a problem.
slmayor
shasta lake ca
Posted: 06/11/08 09:40am Link  |  Quote  |  Print  |  Notify Moderator
We tow a Heartland Bighorn with a long bed. Not only a long bed, but a pullrite slider hitch to boot. We had the hitch before the truck and it simply was too good a hitch to give up. Factory helped set us up with brackets. Probably upgrade the truck in the future, but will keep the hitch as we may go to a SB. Easy to back into sites with the LB.
magster
Palm Bay, Florida
Posted: 06/11/08 09:42am Link  |  Quote  |  Print  |  Notify Moderator
The only downside to a longbed is when you're NOT towing. It takes up a lot of room in parking lots, particularly ones that have narrow aisles.
Cheers,
Magster
2 retirees
2 dogs, 1 cat and a foul-mouthed parrot
2003 29RL Dutchmen Classic, "The Ark"
2001 Dodge 2500 diesel
up2nogood
Utah
Posted: 06/11/08 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Frank
I don't think that is a correct statement, you are obviously comparing one style or same style of trucks, or you need to elaborate on what you mean . Short bed versuses long bed crew cab yes,short bed versuses long bed if the short bed is a crew cab and the long bed is a extended cab then its probably sixes, if the short bed is a crew cab and the long bed is a standard cab then the short bed has the advantage on fulcrum as it is a longer truck from the center of the rear axles foward. So its not always fair to make these statements without explaination . If people are not well versed in this short bed long bed issue when it comes to towing they would think all short beds have a disadvantage, and that is not true.
