RV.Net Open Roads Forum: Travel Trailers: chocks-what size pipe clamps?
 > chocks-what size pipe clamps?
crazymama2
Wisconsin
Posted: 06/11/08 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
I want to make some wheel chocks using pipe clamps but I am unsure what size pipe clamps to use. 1/2 " or 3/4"? Also, I am planning to cut the angles at 20 degrees. Is this correct? thanks for your help
pdvandusen
Snow Hill, NC USA
Posted: 06/11/08 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
I would use 1/2" as you don't need a lot of pressure to stop the wheels from moving. It would help if you designed something to lock the chock in place to secure your trailer.
Doug & Mary Ann Van Dusen and Phoebe (the dog)
2008 Chevy 1500 Silverado 5.3L LTZ 3.73, HD Trailer Pkg.
2008 JayFeather LGT 31E
Equal-i-zer, Prodigy BC and TomTom GPS
greg121
TX
Posted: 06/11/08 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
I used 1/2 inch. I just eyeballed the angle. Don't have any locking mechanism. All the preceedng work fine.
old guy
Oregon (pronounced Or e gun)
Posted: 06/11/08 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
you can always hold the block of wood behind the tire about where you want it to sit and using a pencil, mark the block of wood then cut it as close to the line as you can. that way you get the proper angle to sit on the tire for max pressure
crazymama2
Wisconsin
Posted: 06/11/08 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for your help. I'll get 1/2" and put the wood block behind the wheel to get the angle. I will try to make them tomorrow.
MNRon
MN
Posted: 06/11/08 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
I used 3/4" because I already had them, but I'm sure 1/2" would be fine. I did a curve to roughly match the tire arc and then drilled holes for the pipe in the middle of the 4x4's so that everything held together and I could place and tighten them with one hand.
lat471
Lebanon, PA
Posted: 06/12/08 05:53am Link  |  Quote  |  Print  |  Notify Moderator
I liked the tightening mechanism better on the 3/4 so I went with them. A couble of quick twists with the crank and their set. On the Cameo the blocks are cut with a 66deg angle.
07 Cameo LXI F35FD3
R Taj-We-Haul
