04superduty
Michigan
has anyone replaced the black corugated plastic under the trailer? someone mentioned FRP but it seems alittle to thin. around .090 thick. any other ideas on how to replace the existing sagging underbelly.
04 F350 6.0PSD/TS EC SB
07 Outback Sydney edition
tjar66
Portland OR
Check around with a local screen printer and ask them where they get coroplast or corex. It is the same stuff you should be able to pick it up in 4x8 sheets for aroung 10.00 a sheet
2006 Dodge Ram 3500 Cummins
2007 Desert Fox 305j
2004 TRX 450r Mine
2005 Yamaha Raptor 350 Wife's
2006 Honda 300ex Sons
2007 Honda 250ex Daughter
2008Wildcat
PA
Use some metal crossbraces under the plastic sheeting to hold it up.
BruceStarkey
Ontario, Canada
Firstly, make sure you haven't got a leaking black tank. Somethings causing that stuff to sag. That would be one nasty surprise in your driveway!
Today is just the tomorrow you worried about yesterday!
'04' International 4400 LoPro 310Hp/950FtLbs 10Spd Harley/RV Toter
'05' Mobile Suites 38RL3
'01' Harley Ultra in the bike barn.
THE BIGPUNN
west michigan
whats FRP? i was looking into replacing mine as well.
07 Chevy 2500HD D-Max!
05 Forest River Wildcat 31 QBH
John H
Kansas City Mo.
Fiberglass Reinforced Panel
John H
Charlie D.
Gonzales, La.
I don't think I would use FRP. It is usually in thin sheets as OP stated. Bolted under a rig and subject to wind and a lot of flex, IMO, would cause it to crack.
Enjoying Your Freedom?
Thank A Veteran
2007 Holiday Rambler 32SKT
2006 Chev LT D/A CC
Ottawa Campers
Ottawa, Ontario, Canada
I took an idea from someone on this forum and reinforced the sagging corrugated plastic panels with 5/8" steel electrical conduit (round pipe),flattened out at each end and bolted to the main frame, placed across the width of the trailer every 2 or 3 feet.
It took almost all of the sag out, and I no longer worry about those panels coming loose and getting caught by the wind.
2006 Grand Surveyor 240BH
2004 GMC Sierra 2500HD 4X4 CC LB 6.0litre 4.10 gears
18K Reese/Hidden Hitch Signature Series Hitch
Prodigy Brake Controller
04superduty
Michigan
BruceStarkey wrote: Firstly, make sure you haven't got a leaking black tank. Somethings causing that stuff to sag. That would be one nasty surprise in your driveway!
i caused the sagging,i removed the underbelly and for some reason i cant remember why. i did spend around 2 hours ziptying up all the wires and moving the water lines around, its amazing how much waste their is in extra wiring and water pipe under our trailers.
Teacher's Pet
SD.. Fulltimers. Goshen IN summers
Pull-Tab bought the material from RV Surplus & Salvage in Elkhart IN when he re-did his belly liner, I believe.
'06 Phaeton 40' QSH
'03 Ford Sport Trac
Scottiemom's Pet
Husband to Dale
2 Traveling Scotties
RV.net Rallies 11, Other Rallies 7, Escapades 5
2005 F/T Class
Our Travel Blog
Where are we?
