RV.Net Open Roads Forum: Folding Trailers: WDH-Clearance?
 > WDH-Clearance?
desertrush
pc, utah
Posted: 06/11/08 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
Strange question...I have a 2007 toyota 4 runner with a v6. I also a evolution e1. I have been reading many posts on the WDH issue. From what I have gathered and read; a WDH would be a good investment. Right???
However, I was wondering if anyone has had any clearance issues with the added hardwarde dropping below the trailer???
Any insights and information would be much appreciated!
Thanks again,
Mike
pete42
Jamestown, Ohio
Posted: 06/12/08 03:30am Link  |  Quote  |  Print  |  Notify Moderator
The hitch doesn't drop below the trailer just the tongue, the axle and depending on what's under your trailer would still be lower.
He Ruide
Cincinnati Ohio
Posted: 06/12/08 05:54am Link  |  Quote  |  Print  |  Notify Moderator
Mike, The WDH bars will be just a couple inches under the tongue like this and will not present any clearance issues.
Ruide
Fleetwood Evolution E3 - Yellow (DW let me get a Yellow one since she wanted an E3 with a slide out )
Hummer H2 - Black (DW vetoed the Yellow one, but I got two Yellow Hummer Folding Mountain bikes )
My Pics and Mods and My Weekly Blog
Eurocamper
Salt Lake City, Utah
Posted: 06/12/08 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
A weight distribution hitch won't reduce your ground clearance appreciably, but it will reduce the trailer-hitch articulation when you take it off road. It's probably best to disconnect it when the going gets rough.
Fleetwood E1 with an Equal-i-zer WDH:
Ron
2008 Fleetwood Evolution E1
2007 Nissan Xterra
1992 Isuzu Trooper
Ex 1997 Volkswagen Eurovan Camper
cada
Tavares, FL
Posted: 06/13/08 08:17am Link  |  Quote  |  Print  |  Notify Moderator
I have a dip in my driveway, so I can't take mine out of the driveway with the arms on. Though other than that, I've never had any issues elsewhere.
We probably have the same or similar suspension, so if your pup is less than 3k lbs, I'd probably skip the wdh. I can tell a slight difference when I use mine, but I wouldn't have one on my 4k one if I didn't get it for free. You can get a friction sway bar for quite a bit less.
Dave
2004 Fleetwood Hemlock
2007 Toyota Tacoma
bbartschi
Riverdale, Utah
Posted: 06/13/08 10:02am Link  |  Quote  |  Print  |  Notify Moderator
eurocamper,
I looked at you picture that you posted on the previous message showing your weight distribution hitch set-up (equal-i-zer) and I have a couple of questions on how you set it up.
I have a E-3 with a equal-i-zer WDH set-up, my question is with the double tube trailer frame that we have on the Evolution models how did you set-up the L-bracket on the trailer? Where did you bolt the L-bracket? Did you flip the L-bracket upside down? In what hole where you able to put the L-bracket in?
When I installed the equal-i-zer WDH on my trailer, I talked with a rep from equal-i-zer several times to try to determine the best way to install this WDH on trailers like ours with the double tube frame.
I am just curious to see what you experience has been with this product.
 > WDH-Clearance?
