RV.Net Open Roads Forum: Tech Issues: Chip for Mercedes 210hp M2 diesel
 > Chip for Mercedes 210hp M2 diesel
janree
Knoxville, TN
Posted: 06/11/08 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know if a performance chip is available for this type of engine?
If so, who makes it and where can I get one?
Thanks
jwalker
Home is Knoxville, TN
Currently, Tucson, AZ
Southern AZ in the summer... where the driving gloves of choice are oven mitts!
Our Geocaching Blog, brought to you by RV.NET
Geocacher's Extraordinaire
glsurrat
Virginia
Posted: 06/12/08 04:21am Link  |  Quote  |  Print  |  Notify Moderator
Do you know the model number of the engine? In the current crop of Mercedes engines, the smaller engine can be rated up to either 300 or 330 hp. A dealer could probably up-rate yours (for a price) that would keep any warranty in effect.
Greg
Full-timing and soon to be retired US Navy Master Chief
Enjoying Champagne on the King Ranch!
'06 King Ranch F-350 Dually Diesel 4x4 Long Bed Crew Cab w/ Tow Boss
'07 Champagne Edition NuWa Hitchiker 3 axle 4 slide 37CKRD /w TrailAir all around
janree
Knoxville, TN
Posted: 06/13/08 12:00am Link  |  Quote  |  Print  |  Notify Moderator
It's a MBE900-210 6.4L
Where would I find out the rating?
Deen
Vancouver, WA
Posted: 06/13/08 12:16am Link  |  Quote  |  Print  |  Notify Moderator
Thanks
Be sure and check the cooling capacity you will need vs. what you have! That's what keeps the CAT 3126 from being uprated a lot of times. In boats with unlimited cooling it can go to 450+ hp, but in Rv's it limited to 330 or maybe 350 (C-7) but still with 860 ft lbs torque.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
glsurrat
Virginia
Posted: 06/13/08 03:43am Link  |  Quote  |  Print  |  Notify Moderator
From http://www.detroitdiesel.com/engines/mbe900/performance.aspx :
Power to Pull
When it comes to acceleration, the MBE 900 is extremely versatile compared to other engines in its class. Available ratings range from 190 HP/520 lb-ft to 350 HP/860 lb-ft. The MBE 900 can power any Medium-duty application.
Probably any big truck dealer can handle the engine as it would be an option in most Pete's, KW's, Freightliners, etc. I know the local Freightliner dealer has at least three M2's sitting on the lot with MBE's in them.
