RV.Net Open Roads Forum: Dinghy Towing: braking system
Search only in Dinghy Towing
 > braking system
trtogether
canada
Posted: 06/12/08 09:46am Link  |  Quote  |  Print  |  Notify Moderator
We are just getting set up to tow 4 down and are having trouble deciding on braking system Checking through the net most threads are about the car and not the braking system or problems installing system. We tried Even Brake and had nothing but problems and are now looking at SMI or Brake Buddy. What do you use and why do you like/dislike it?
Larry & Linda
Lansing MI/????
Posted: 06/12/08 09:54am Link  |  Quote  |  Print  |  Notify Moderator
I'm using the AirForce One from SMI.
I chose it because it uses the air brake system on the truck and is proportional.
Larry
Rollincool
Always Rollin
Posted: 06/12/08 10:01am Link  |  Quote  |  Print  |  Notify Moderator
We use the Brake Buddy and have had no problems over a year and a half now.
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Yellowstone 5290 6.0
2007 Chevy HHR Toad 2LT 2.4
1967 Chevy Camaro Pro Street 468 BBC
The Most Fun Radio, on Radio - Tom Kent Radio Network
Burp
St. George's Island, MD
Posted: 06/12/08 11:04am Link  |  Quote  |  Print  |  Notify Moderator
We use the BrakeMaster. It depends on air pressure from the MH. If you have a DP then you just tap into the brake system. If you have a gasser like us, you have to install a compressor in the MH. When towing we have to install a pneumatic device between the floor and the pedal in the toad. Takes about 2 minutes. Initial installation can be a hassle but easy to use after that. It is proportional and you don't even think about it. There is a small red light on the dash of the MH to tell you when the brake pedal in the toad is pressed, that is all that is required to verify it is working. Cost is about the same as the portable devices but I trust it more.
2007 Winnebago Voyage 33V (Workhorse, W20)
2007 Ford Escape, Falcon 2, BrakeMaster
Me, the Wife , Edgar And Gus
Places we have camped in an RV
jauguston
Bellingham, WA
Posted: 06/12/08 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Ready Brake!
Proportional braking, 30 second connect-disconnect, nothing to lift into and out of the toad floor and less than $400.00.
I have used mine for 30,000 miles plus and it works great.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
275 RV injectors
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Big Katuna
Deland, FL
Posted: 06/12/08 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Another satisfied Ready Brake user. I use the Ready Brute tow bar with the braking system built in. An aluminum and stainless steel self locking tow bar with brake for what other people pay for just the braking system, about $700. Also will work with anybodys baseplate so you aren't locked into a specific baseplate company. ;
My Kharma ran over my Dogma.
offthewall
New Jersey
Posted: 06/12/08 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
I have the SMI Stay-N-Play Duo in my Jeep Wrangler. Fantastic. Simply flip the ON switch and you are ready to go. Uses vacuum to apply the brakes so it is not pushing against a dead pedal which can subject the toad to forces greater than it was designed for.
2008 Gulfstream B Touring Cruiser
rogerswann
Rhode Island
Posted: 06/12/08 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
US Gear here...
jauguston
Bellingham, WA
Posted: 06/13/08 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
Offthewall,
Your last sentence reads like it must have come straight out of the SMI sales brochure (-:
Two Jayhawks
lenexa ks
Posted: 06/13/08 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Me too.
2002 Safari Zanzibar
CAT C12 455/1550
Allison 4000
Saturn Vue w/ReadyBrake
FMCA# 390819
 > braking system
