MH4Two
Ickesburg, PA
I did a fairly large review of the latest SMI Air Force One system in this thread
I can't comment personally on how it compares to other brake systems, since this is the first and only brake system I have owned or used, but I must say overall, I am very pleased with the SMI system.
(edited link)
Me, the DW, 2 dogs and more.
1998 Overland Larado, 41', one slide, 325 Cummins, '02 Jeep Liberty with SMI-Air Force 1.....
Deen
Vancouver, WA
Burp wrote: We use the BrakeMaster. It depends on air pressure from the MH. If you have a DP then you just tap into the brake system. If you have a gasser like us, you have to install a compressor in the MH. When towing we have to install a pneumatic device between the floor and the pedal in the toad. Takes about 2 minutes. Initial installation can be a hassle but easy to use after that. It is proportional and you don't even think about it. There is a small red light on the dash of the MH to tell you when the brake pedal in the toad is pressed, that is all that is required to verify it is working. Cost is about the same as the portable devices but I trust it more.
We also have the BrakeMaster that I use when we tow the Jeep. Works well and will use it again when we get another vehicle that can be towed four down.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
mscamping
any place, USA
I second offthewall's comments..
2003 Holiday Rambler Neptune 36 PBD 37' - ISB 300 Cummins w/Allison MH2000 5 speed
2005 Malibu Maxx w/Blue Ox Aventa II SMI Stay-n-Play Duo
FMCA - HRRVC - Chapters - 56,57,& 419 - Good Sam Life Member - C2C - Coach Net - full timers
Mike & Sharon
bird1dog
Tennessee
We use SMI Stay and Play on our CR-V and are very pleased. Great company. Great people. Great product.
Diplomat Don
Moorpark, Ca
We have the SMI Air Force One. Haven't towed alot with it yet, but it works great and I like the proportional braking on a vacumn assisted brake pedal. It also has a break away system that applies the brake on the toad if they separate. I did the install myself. It took all day because I'm very meticulous and literally had no room under the hood for their components, even though the components are small. I'm guessing I could do it in about 4 hours now.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2007 Dodge Dakota 4WD
topflite51
In The Desert of Nevada
Another very satisfied ReadyBrake customer.
David
Just rolling along enjoying life
UltimaRV
USA & Europe
We use the SMI Air Force One and I just read the recent post above that SMI came out with a good improvement recently that uses two air tanks, one on the toad and one on the coach. Makes things incredibly simplier.
The present system is very good, but the updated one sounds great.
Dian, Robert & Precious - Presently RV'ing in Europe!
2000 45' Featherlite Vogue 5000, tag, slide, Detroit Series 60
2006 19' Towcorp enclosed trailer w/60" tongue
2004 13' Ultima GTR (9.9 seconds standing quarter mile)
lfeather
Titusville, FL
Larry & Linda wrote: I'm using the AirForce One from SMI.
I chose it because it uses the air brake system on the truck and is proportional.
Larry
DITTO! If you have air brakes on your MH, this is the way to go IMO.
Larry, Debbie, Tiki and Tomi
USAF Retired
2003 36' Country Coach Allure #30856
2008 Tacoma Toad
SMI Air Force One toad brake
lfeather
Titusville, FL
UltimaRV wrote: We use the SMI Air Force One and I just read the recent post above that SMI came out with a good improvement recently that uses two air tanks, one on the toad and one on the coach. Makes things incredibly simplier.
ULTimaRV, what is the benefit of the second air tank?
UltimaRV
USA & Europe
It acts like a secondary tank(or another auxillary tank) onboard the coach as not to invalidate the coach warranty by connecting an outbound port directly to the coach's air line. Between this and the port sits a rugged one-way valve unit.
Another, much smaller tank, is located within the controller onboard the toad. This is incase of breakaway.
