RV.Net Open Roads Forum: Truck Campers: happy jack or Tork Lift, what better?
 > happy jack or Tork Lift, what better?
Page of 6
mrxman69
Los Angles
Posted: 06/12/08 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
i just got my first truck camper. eagle cap 850 going to put on a 2007 Dodge MegaCabe 2500 4x4 Diesel. What is a better system to use Happy Jack or Tork Lift?
nastybynature
Vancouver, WA
Posted: 06/12/08 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
I use both. Torklift up front and Happi Jack in the rear. I am only a little over 2000 lbs fully loaded though. If you are heavy I would go torklift front and back IMHO.
Tony
'01 Ford F-250 SD/CC/SB 7.3 PSD with some mods
'98 Lance SL 185
'07 6X12 Enclosed full of sand and dirt toys
mrxman69
Los Angles
Posted: 06/12/08 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
thanks! what is IMHO?
RevLeonidas
Oregon
Posted: 06/12/08 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
In My Honest Opinion
ab257
PA
Posted: 06/12/08 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
or In My Humble Opinion
Northeast PA
Ford F350 (2008 XLT CC LWB 6.4L Diesel 4x4 ESOF 3.73 DRW 17"A/S)
Host Yukon, Single Slideout, Tent Option, Solar, 2-way Fridge, AGM.
mrxman69
Los Angles
Posted: 06/12/08 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
got it! i guess you all can see im new to this. I'll order the torklift system, thanks to your professional opinion.
d3500ram
9,500 feet in summit county, colorado
Posted: 06/12/08 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
What, if any, type of 4WD'g do you do? I go off- road quite a bit where I live and I have the Tork- Lift(TL) set up. I have found that in places I have to dis- assemble the front mounts (take off the fastguns, pull the tubes)to pass over rocks, tree stumps, etc. This is less of a concern with the HappiJacs(HJ).
If you are exclusivly on- road or not in extreme off road conditions the TL's will be fine.
2005 Dodge 3500 SRW, Qcab, NV-5600, diesel, 4WD, Helwig rear sway bar, 9000XL
T.W.C. (temporarily without camper)
mrxman69
Los Angles
Posted: 06/12/08 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
i don't really do too much off road at all. i just want the most secure system. i don't think im a fan of the Happyjack things sticking out of the side of my truck.
Gary3
Windsor, ON
Posted: 06/12/08 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
I,ve had Happijac on all my trucks and there the most easy to use and keep the camper in place on rough roads.Torklift is just a more modern bellybar.
Gary  Lance  1181 solar Gen.
mark1228
Helena, MT
Posted: 06/12/08 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
Tork lift is by far superior. The only way to go IMHO
Page of 6
