RV.Net Open Roads Forum: Hellwig Rear Swar Bar Inst. Pics F350 4X4 SWB
 > Hellwig Rear Swar Bar Inst. Pics F350 4X4 SWB
hotvet67
michigan
Posted: 06/13/08 07:25am Link  |  Quote  |  Print  |  Notify Moderator
I like to see pictures of upgrades to our TC's and the test reports - so heres mine on the Hellwig Rr. sway bar install.
Hellwig has a new hammertone paint finish .
Since the F350 sits so high even loaded the side links should have good ground clearance for off road use.
Well worth the $$ spent - Now handles flat around corners without that back and forth movement around turns.
Handles much better at highway speeds , switching lanes etc , payload on this F350 is 3725lbs , Lance 845 is 3000 + lbs , Rig weighs in at 11,100 lbs +
jlfiber
Omaha
Posted: 06/13/08 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Did your F-350 have the EOM swaybar already and you upgraded to the Hellwig?
2008 F-350 CC SRW LB 4x4 V-10, 2008 Northstar Igloo 9.5
CISCO8325
Peoria,az.
Posted: 06/13/08 09:09am Link  |  Quote  |  Print  |  Notify Moderator
looks good ,now paint your drive shaft.hee hee LOL
mastercraft1995
Salem, Or
Posted: 06/13/08 09:19am Link  |  Quote  |  Print  |  Notify Moderator
How much was it?
1999 F-350, Lariat, PSD, C/C, 4x4, Long Bed.
2004 Malibu VLX.
1994 Lance 880.
JoeChiOhki
Keizer, Oregon
Posted: 06/13/08 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Mk, here's a better question, how the devil does that thing keep from just twisting right around the axle? From the looks of it, it uses a U-Bolt clamp reminiscent of an exhaust pipe clamp and from what I can see in the close up pictures they're smooth.
Another question is, what exactly to those arms attach to up on the leaf spring or are they bolted to the frame rails?
CB Channel 17 Space Ghost
'1991.5 Dodge W-250 Power Wagon - Club Cab Long Bed V8 5.9L 4spd H.D Auto 4x4 4.10 Gears
'1987 Pullman Mini Camper
'2004 Bi-Mart 4x8 Cargo Trailer
mrblaine
SoCal
Posted: 06/13/08 09:44am Link  |  Quote  |  Print  |  Notify Moderator
JoeChiOhki wrote:
Mk, here's a better question, how the devil does that thing keep from just twisting right around the axle? From the looks of it, it uses a U-Bolt clamp reminiscent of an exhaust pipe clamp?
You mean like the same u-bolts that hold the axles connected to rear leaf springs? Or the ones on the Ford axles that hold the rear shock mounts on?
05 Dodge 3500 4x4 DRW Long Bed 4dr
07 Lance 992
III so far.
Boatycall
Tacoma, WA
Posted: 06/13/08 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Ditto----
Inquiring minds want to know.
'01 F350 CC DRW 4x4,4" turbo back exhaust,SCMT,pyro tranny temp& boost gauges,4.10 gears
'03 Arctic Fox 1140,4 Trojan T105s,1.5kw inverter,icemaker
92 YJ 35's,6" lift,ARB lockers,Ford 8.8, 8k winch
Honda 400ex
10k 24' toybox
221, 221, whatever it takes.
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/13/08 10:33am Link  |  Quote  |  Print  |  Notify Moderator
The factory Ford sway bar bracket is also held to the axle with u-bolts, but they don't rotate around the axle due to the flat shape the bracket backs up to. The leaf spring u-bolts don't rotate around the axle tube either due to the spring pads welded to the axle tube that hold the leaf packs in position.
My guess is those locator links don't attatch to the leaf springs. Behind the spring in the picture, they probly attatch to the frame.
I would also like to know if this bar is replacing the factory bar?
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/13/08 10:35am Link  |  Quote  |  Print  |  Notify Moderator
My question is, why don't any of the manufacturers paint the driveshafts??? Seems rediculus to leave it bare and just let it rust out from day one...
JoeChiOhki
Keizer, Oregon
Posted: 06/13/08 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Mine's painted. Flat black. I know how U-bolts work on springs, there's also a hole in the plate on the axle that the pin from the springs drops into to keep it from slipping. What I didn't know about is there being a flat spot that the bolt catches up in on the other side of the axle. I have a factory sway bar on my truck, but on the front, The sway bar's mounts are bolted to the truck's frame and the little arms then extend from it and bolt onto the axle brackets.
