RV.Net Open Roads Forum: Fixing water damage on the old Dodge (pics)
 > Fixing water damage on the old Dodge (pics)
Page of 67
Class C Motorhomes Related Tips
MichaeleH
Fort Lauderdale,FL
Good Sam RV Club
Posted: 06/16/08 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
This is really great and what makes this site great. I only wish I had building skills. But I like to see your skills at work. Keep those pic's coming and if you need a job maybe I will buy a used leaking RV. It might be cheaper than what they want on the lots.
Skyliner
Duluth, MN
Posted: 06/16/08 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
I finally finished the tear out of all of the rotten wood in my cabover. I ultimately had 2 issues. The first was a leak in the vent, which was the reason for my ceiling starting to sag. When I tore things out I found that the vinyl had separated from the wood backing. As I pulled it down, that last layer of wood stayed in place with the foam insulation behind it. It was dry so not sure if I will tear that out or not yet. All of the studs in the ceiling appear to be dry and solid.
The big issue was leaking below the front window and a bit along the bottom side seams. I could see where the PO had caulked the heck out of those areas, but after tearing everything out, I found a bunch of little pin holes in the skin along the front and corners. I am not sure if these were the result of screws or staples rusting out, and the small pieces migrating to spots where they continued to rust against the aluminum, or if it was something else all together.
My lower end was so rotted out that the wood was literally turned to compost. What was there was mostly mush and came apart when I pulled the decking up. I was lucky in that some of the pieces were labeled with their lengths where I could still read it. I am using that as a guide, but for the most part am redesigning the platform and adding some additional support along the way.
I have some pictures, post tear out, that I will post when I get a chance. I will also post some pictures from the rebuild. I think I am lucky as it would appear I can do all of this from inside.
The bright side to this project so far is that one of our local home building supply stores is shutting down for a remodel. Everything was on sale for 30% off, and I was able to pick up everything I needed to do this job, plus a few tools I was missing, and at a good discount. They had rolls of repair tape for aluminum roofs, so I bought 4 rolls, which should be enough to seal all of my seams in the roof and also shore up some of those areas with the pin holes. I will be sure to turn on all the interior lights and walk around it at night to spot any other holes I may not have noticed so far.
Spectramac
Monroe, WA
Posted: 06/16/08 11:15pm Link  |  Quote  |  Print  |  Notify Moderator
I got started tearing down the right side tonight, so far it's looking WAY better than the left side...
Look! boards that aren't black!!!
I think I can just replace the lower frame boards and plywood, put on some new paneling and be done. Be a nice warm up before I wade into the rest of it.
Malcolm
ron.dittmer
I Will Be Dancing With The Stars On 1/23
Posted: 06/17/08 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Hopefully your floor is in reusable condition, or this becomes hopeless.
If I learned anything in life with home projects......don't waste any time trying to salvage the cheap stuff, that could be quickly removed and replaced with new.
My thoughts on this project is to rebuild (maybe replace) one or two adjacent walls at a time, and do the roof last. I wouldn't want to tear it down to the point that there is nothing to refer to anymore.
If this were my project, I would change the following for sure
- reshape the cab-over bed for improved aero-dynamics
- have only one small screened window on each side of the cab-over bed. Delete the front window for sure for water infiltration reasons
- replace every window in the entire RV with new ones. You can pick different sizes too.
- finish the RV in sheet fiberglass including the roof. forget the siding and rubber or aluminum roof
- If the roof needs replacing, crown it to eliminate water puddling later which always happens around the heavy a/c unit. When the caulk cracks around the a/c and other roof openings, in comes the water
- use 0.6 CCA treated lumber (or a safer equivalent) for all framing alone, not the more common 0.4 CCA. CCA Pressure treated lumber is a great product but has health concerns. Limiting it's use to framing alone minimizes any concerns.
- use moisture-proof exterior wall board sheathing. What kind needs further research.
- use hurricane ties or other steel bracketry for all frame corner joints. These are commonly found at Home Depot for house and deck construction.
- screw all wood together with high strength coated wood screws. Stainless screws don't rust, but they are a very soft metal and will break easily from the stresses that occur during RV motion. Pre-drill the screw holes near the ends of any framing to prevent splitting
- rewire everything with 12 gauge wire for 110v, etc. All wiring in there is likely too old with brittle insulation for continued long term use.
Regardless of condition, be sure to replace or spray bleach on all good wood that had mold grown on it. You wouldn't want to have health problems from this.
* This post was edited 06/17/08 10:09am by ron.dittmer *
My wife & I are "Dancing With The Stars" for PADS on 1/23
Read about it in my "View Profile"
Then scroll down to "More About Me"
Spectramac
Monroe, WA
Posted: 06/17/08 10:43am Link  |  Quote  |  Print  |  Notify Moderator
I like a lot of those suggestions, but I had planned on reusing the old sheet metal so reshaping and changing window sizes will be pretty tough. This is going to be an inexpensive rebuild to match the cheap purchase price. My wife jokes around that we want to go from a $100 motor home to a $1000 one.
If I find some extra metal paneling I wouldn't be against reshaping the front. I'll have to look for someone parting out an old one around here....
Spectramac
Monroe, WA
Posted: 06/18/08 12:09am Link  |  Quote  |  Print  |  Notify Moderator
I got the right side all de-skined today.
Then got to looking at the roof....
It has 2x2s on roughly 16 inch centers. My plan is to change this to 2x4s on maybe 24 inch centers reshaped down to 2 inch on the ends to make a crown for runoff. Maybe even reshape the nose on the overhead downhill in the front for better wind resistance. I'm talking with a couple local people about finding some extra skin to omit the front window (it was cracked anyway). We'll make a 21st century C out of it yet!
Spectramac
Monroe, WA
Posted: 06/18/08 12:36am Link  |  Quote  |  Print  |  Notify Moderator
I was thinking about something like this:
Instead of this...
PapPappy
Wilmington, NC
Good Sam RV Club
Posted: 06/18/08 02:26am Link  |  Quote  |  Print  |  Notify Moderator
With the right aerodynamics, you could probably get, oh 9 mpg instead of 8
As long as the windows are OK, I don't see any reason not to reuse them. I would eliminate the front one on the cab-over....which may present your metal problem, but if you cut the size of the cab-over enough, you may have enough sheet metal.
The suggestions about re-wiring are good, as were all of that poster's suggestions. I realize that you are trying to keep this within budget....and that budget is almost non-existant, so try to figure which "upgrades" are best for you. Just keep SAFETY the priority.
Your idea for the roof joist is a good one, but you may find a problem with the various thru-roof fittings....will the fan and A/C reach down through the thicker overhead? I'm sure they make them that will, but will the ones you have??? You want to keep things pretty much the same. Just a thought
Love the pictures...keep them coming!!
Bill
Bill & Claudia / DD Jenn / DS Chris
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie & Beau
RIP: Cookie (Sheltie) & Gidget (Lab-mix) over the Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
Spectramac
Monroe, WA
Posted: 06/18/08 10:40am Link  |  Quote  |  Print  |  Notify Moderator
I was worried about that very thing last night, so I went back out and pulled the the inside cover to the A/C unit. It has around 3 inches of extra mounting hardware so I think I'm good. I'm also planing on simplifying the roof some by removing the old crank up antenna, the roof rack and ladder. I never needed the extra storage before anyway.
RedRollingRoadblock
Oregon
Posted: 06/18/08 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
About the extra skin for the roof... A friend had an older MH with lots of rot in the bunk area. He got the shop to sell him the aluminum skin that is used on truck trailers. Not sure of the thickness that it comes in. He started under the bunk (eliminated the window) and went over the rear to just above the rear window. Made a good one piece, leakproof roof. You could get it at a heavy duty trailer repair shop. Comes in rolls thousands of feet long they just cut off what you want.
Good luck on the project. Maybe you can make it a $1200 MH.
Page of 67
