RV.Net Open Roads Forum: Class A Motorhomes: Onan not playing well
 > Onan not playing well
T bone
Top O Texas
Posted: 06/15/08 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
We went to the local races this morn. I started the Onan(5500 Marquis) at 7:30 A.M. It ran without a hiccup until 3:00PM then it would die for no reason. It would restart easily and die again 30 min later. I checked the oil and added 1 pint.Same result. It would die when the second AC kicked in. Motor would stumble and die. I got home and shut off the breakers and done some looking. When I got the throttle linkage and revved the engine a little , it would die just like the fire had been shut off. When it decided to die, there was nothing to be done about it.Taking off the load did not help.I just replaced the air filter and checked and cleaned the plugs.Also drained carbon from muffler, which there was none.But when it is running it is running smooth as silk.Thanks for any insight. WE are leaving in the morning for the lake.
Model 5.5BGMFA26105H
Serial: SNC990874252
Edited to add generator specs.Just got back from the lake. Had an accident.Fell over backwards over a cooking grill.Went to Dr. and got x-ray no broken bones just badly bruised.
1999 Georgetown 325S,V-10 Ford.
2002 Ford Ranger Edge toad
carrying a 2001 Yamaha Warrior.
* This post was edited 06/23/08 04:58pm by T bone *
gunny357
North Carolina
Posted: 06/15/08 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Model/spec/serial number of the genset would be helpful to know what you have. Is it fuel injected or carbureted? Mechancial governor or electroninc? What controller? New one that displays fault codes?
Fuel level in the MH? Genset shoul dstop if less than 1/4, sometimes 1/3.
You added oil. Was it low? What kind/type oil are you using?
When was it last serviced?
Polishnurse
Schodack, NY
Posted: 06/15/08 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
It will also kick out on high temp. I didn't see fuel filter in your list. If its got some crude in it, it will strave the carb. coking it down. JM2Cents Bill
Bill S.
Indian River, Delaware
Posted: 06/15/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
How much fuel was in the gas tank? Generator pickup tubes are intentionally set well up from the bottom of the tank, so you cann run your tank out of fuel and leave you stranded. Some pickup tubes are set ridiculously high, maybe 1/3 tank from the bottom. Did you have less than a third tank of gas?
You could try filling the tank and trying the gen, or even connecting a seperate portable tank and see if it runs. That would rule out a clogged pickup tube too.
Maybe someone else has some other ideas.
Bill, (aka Capt.Bill)
Indian River, De
2002 Horizon 36LD, Cat 330
Practicing retirement!
T bone
Top O Texas
Posted: 06/15/08 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Fuel filter good, 65 gallon tank full.I don't think it was a temp problem,Ambient was 97 with a strong breeze. When I opened generator bay door it really didn't seem that hot,probably 120 .
Tsalla Apopka
Pine Ridge, FL
Posted: 06/15/08 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
That sounds very much like the regulator board is going out. If it runs fine until the load jumps up and then dies that frequently is the controller(regulator?) board.
Denny & Karen
Florida's Beautiful "Nature Coast"
Holiday Rambler Traveler 29' (A TREK in disguise!!)
Brit,TDI,BH & Claire,TDI (Belgian Sheepdogs)
Glady(Morgan Mare - retired),Toes & Beemer(Barn Cats-retired)
WA4OMG (Old Mangy Goat)
jeffnkelly
St. Louis MO
Posted: 06/15/08 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
Check the oil... It has a low flow sensor... I experienced it right before scheduled maintenance..
Just My $.02 worth...
Smooth Roads!!!
2006 Damon Challenger 372F Triton V10
2007 Ford Edge
JeffnKelly
St. Louis MO
Carvin Marvin
Livingston, Texas, USA
Posted: 06/16/08 05:58am Link  |  Quote  |  Print  |  Notify Moderator
Could be ccracked fuel hose. Prety common.
Scottwig
Belvidere, IL
Posted: 06/16/08 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Our 5500 Marquis acted the same way. The diagnostic code indicated lack of fuel even though the tank was full. The dealer replaced the fuel pump (still under warranty) and it has run flawlessly for 65 hours since.
Good luck!
Herewego
Larry Cad drives the ACORN Express!
Posted: 06/16/08 07:58am Link  |  Quote  |  Print  |  Notify Moderator
If you answer gunny's questions, he may be able to help you, versus everyone guessing.
2004 Coachmen Aurora on a FORD V-10 Chassis
2004 Jeep Liberty
Don't take your organs to Heaven. Heaven knows we need them here! Dave has a dog named Muffy and Mike owns a Cockapoo!
