RV.Net Open Roads Forum: Class A Motorhomes: black hose attachment ?
 > black hose attachment ?
Dynasty40
Hangtown, Northern California
Posted: 06/15/08 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
Didn't they use a "Y" connector in the movie RV????...
Dennis and Debi
Monaco Dynasty Baron 40PFD
wallynm
Los Alamos NM
Well suki981 after reading these replies did you win or lose? Me white and black so not mix!
Have a Cat Engine Yahoo Group or Cat RV Club Web Page
Have a Freightliner Yahoo Group or FCOC Web Page
wallynm@yahoo.com
2002 DSDP 3567 PUSHED BY KITTY KAT
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Bumpyroad
Virginia
Posted: 06/16/08 04:23am Link  |  Quote  |  Print  |  Notify Moderator
assuming that you have a back flow preventor and allow the hose to run prior to removing and hooking up, I see no real danger but I have about 25 ft myself from the Wye. if you have the water running when you shut off the wye valve, it can't back up.
bumpy
Hyall
Davie, Florida
Posted: 06/16/08 05:49am Link  |  Quote  |  Print  |  Notify Moderator
Just remember if on negative pressure if the hose bibb is off the water in the black or white will mix to each other until drain dry or balance out, only if something is left on letting air in
2007 Gulfstream TourMaster T40B MBE 926
2007 Honda CR-V
MC Honda VTX 1300R grey is faster
MC Shadow Aero 750 wife's
DON'T WORRY ABOUT NOTTIN - NOTTIN IS ALRIGHT
itsalleasy
Posted: 06/16/08 06:21am Link  |  Quote  |  Print  |  Notify Moderator
suki981 wrote:
I feel that The black and white water hoses shouldn’t be connected at all. If it is a good hose configuration, 18 inches is too close to the black water fill. I am concerned about the possible health effects of having them so close together.
I am 100% with you. It is nothing but changing a couple of hose connections when he dumps, a cheap hose that probably costs less than the valve and stub hoses. If something should go wrong you are going to be really ill.
I look at consequences, if they become reality would I have done differently to prevent them. In this case I would change hose connections all day, it's not that big a deal, the health effects are.
newxmar
East Otis, MA
Posted: 06/16/08 06:28am Link  |  Quote  |  Print  |  Notify Moderator
A solution, use quick connectors on one water hose. (Be sure that there is a check valve down stream on the black water tank.)
D & M
Laurel, MD
Posted: 06/16/08 06:41am Link  |  Quote  |  Print  |  Notify Moderator
There is no right or wrong in this issue. It's a personal preference.
When we first got the motorhome, I used to connect both. Just because I saw other people do it and thought it was somthing that one should do. I found out that this appears to be a full timer thing. Maybe when we set up for long periods I will consider it again.
After the first couple of times hooking it up, I found that for the infrequent times that I dumped the black tank it was not necessary to keep the black tank flush connected. I can hook it up while the black tank drains.
Plus the wye is just another restriction that causes hydraulic loss.
If you do decide that you have to do this, get a back flow preventer. You can find one at Home Deport or Lowes and they are cheap. More and more jurisdictions are requiring them on domestic water connections. Lots of CGs have them, but people keep stealing them.
Dave & Mary
Isabel (a cuddly little Boston)
Buddy (The Beast) another Boston
2005 Itasca Suncruiser 35A
2003 Jeep Liberty
If it's listed in the Yellow Pages, the government shouldn't be messing around with it.
Tsalla Apopka
Pine Ridge, FL
Posted: 06/16/08 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Seriously then - On our rig there is a place to connect the shore water and also a faucet for water from the RV and then a place to connect water to flush the black tank. I made a short hose that goes from the RV faucet (with a backflow valve built in) to the flush tank fitting. I can flush either with shore water or RV pump water that way. Or if the hose is not connected wash my hands.....
Denny & Karen
Florida's Beautiful "Nature Coast"
Holiday Rambler Traveler 29' (A TREK in disguise!!)
Brit,TDI,BH & Claire,TDI (Belgian Sheepdogs)
Glady(Morgan Mare - retired),Toes & Beemer(Barn Cats-retired)
WA4OMG (Old Mangy Goat)
wny_pat
Western NYS
Posted: 06/16/08 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Against code in my stick house for very good reason, and against my code in the motorhome too!
Tinstar
McKinney, TX
Posted: 06/16/08 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
I would look at it as a worse case scenario. Ask yourself or better, ask him: Is there any way possible for the black and the fresh water hoses/tanks/etc to cross-contaminate. If it's impossible then it would be OK. If there is any way by human error or hardware failure then I would not do it under any circumstances. BUT my time is cheap and the extra water hose isn't worth a trip to the emergency room or worse.
Never pass up a chance to go somewhere
