I check the lug nuts before each trip. If they are all tight I do not check them again. I check the air pressure in the tires each morning before we leave for another campground.
Don
Quote: I check before every trip. I marked the lug nuts to see if there is any movement. Makes checking the wheels that much easier. Also the tire pressure on the trailer and the TV is checked before every trip. Always have the torque wrench and a air gauge in the truck.
Great idea on marking the lug nuts. I'm gonna do it!
Wow! You guy's are really good. I check mine when packing the bearings and one more time after I tow it, just to make sure. Then I forget it until time to pull the wheels again. Never had a problem! I do check the pressure before a trip, then forget it until the next trip. No tire issues either!!
KE5NCP
2002 Chevy CC dually, WW 2003 SLC 3705 Toyhauler, 98 Terry 34.5, 3 slides, 97 Wrangler and a couple of vettes.
