RV.Net Open Roads Forum: Class A Motorhomes: HWH Pump
 > HWH Pump
London Aire
BC, Canada
Posted: 06/16/08 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
If the pump has power going to it but not responding, is it shot?
Mossberg
Tipton, Iowa USA
Posted: 06/16/08 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
As long as there is a good ground for the pump and you have 12 volts. If you have both of those and it don't run then the motor needs repaired.
Stacy
JFG
TN
Posted: 06/16/08 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
sorry
* This post was edited 06/16/08 02:00pm by JFG *
Fred
Polishnurse
Schodack, NY
Posted: 06/16/08 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
There is a starter solinode valve mounted on the side of the motor, If you jump it out, does the motor run, if it does then it's good. If it doesn't it's time to replace. You can Call HWH with the serial and model number and you should have a replacement in a few days. Easy to replace. If you need to raise or lower you jacks in the mean time. There are several things you can do. PM me If you need instructions. Bill
Lug_Nut
Newmarket , Ontario, Canada
Posted: 06/16/08 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
I would first run a jumper cable from a good frame ground to the motor housing. If that does not get it running, it is probably the soleniod switch. As posted, it is easy to replace and is not that expensive.
'07 Newmar Essex 45' ISM 500 4 slides
 > HWH Pump
