RV.Net Open Roads Forum: Beginning RVing: Refrigerator problems
 > Refrigerator problems
captain crunch
Tennessee
Posted: 06/16/08 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
My fefrigerator want get cold . The Led's lights on the Fridge are not solid on AC or battery but is solid on propane. The lights on AC and battery are blinking off and on . The RV is showing level . Can anyone give me any tips on what the problem might be.
Thanks
VernM
Marion County, AR
Posted: 06/16/08 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
The owners manual for the refrigerator will have a guide to the lights. If you have no owners manual, the major brands all have web sites and customer service links.
VernM
GMC Conversion van/Wells Cargo MiniWagon trailer
Sent via HughesNet/SatMex5 Internet Portal
ploiselle
South Shore, MA
Posted: 06/16/08 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Hi
It would help to know what manufacturer, model and year of the refrigerator. Years ago, one manufacturer's refrigerators had similar symptoms and it was a board problem. Should this be the case, you may want to consider Dinosaur Replacement Boards
Try RV Mobile Technical or Gas refrigerator . net for trouble shooting and manuals.
Paul
Forum etiquette.
41' Mountain Aire (MADP) -Spartan- Cummins 350 ISC
2004 and 2005 Jeep Grand Cherokee Limited's - Brake Buddy - CoachNet
captain crunch
Tennessee
Posted: 06/16/08 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
The problem is I don't have a owners manuel . It is a Norcold Fridge. It does sound like a board problem. I have two more weeks to go at the CG.
Thanks for the info
Captain Crunch
erd04056
Where ever we park it
Posted: 06/16/08 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Go to the outside access panel of the fridge. Remove it and you will find a black, plastic cover held in place with 3-4 screws. It also says "danger, High voltage" or something around those lines. You should see a 110 household powercord plugged into a standard plug in receptacle. Unplug it and remove the plastic cover that has the warning on it. This is your circuit board and it has a couple of fuses on it...just like on your automobile.
These are very common for failure. Any type of power surge, will blow the fuses. Check them out before you spend the $$$ on a service call. It may be as simple as a blown fuse.
2005 Kodiak 4X4
40' Carriage 5th wheel
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Posted: 06/16/08 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
I posted a possible solution twice yesterday.
Here Norcold Service Manual
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, Hughes Direcway HN7000S, Satmex5,
http://www.kayepics.com
captain crunch
Tennessee
Posted: 06/17/08 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to everyone who posted about the Norcold Fridge problem. It turned out to be a loose conection on the control board . Thanks again to everone who posted .I will bookmark every thing on Norcold.
This is a great group of people
Captain Crunch
