RV.Net Open Roads Forum: Camp Cooks and Connoisseurs: Weber Q100 gas grll
Search only in Camp Cooks and Connoisseurs
Open Roads Forum  >  Camp Cooks and Connoisseurs
 > Weber Q100 gas grll
SCVJeff
Santa Clarita, CA.
Posted: 06/17/08 12:43am Link  |  Quote  |  Print  |  Notify Moderator
scbwr wrote:
Any problem with a larger tank may be related to not following the instructions. You're suppose to open the valve on the tank, and wait a minute or so before trying to light the grill (leave the grill regulator valve off while you wait.
It's actually the silly check valves in the propane hose to protect us from blowing our collective selves up. A pair of long-nosed pliers fixed mine.
Jeff - WA6EQU
scbwr
Wilson NY
Posted: 06/17/08 06:04am Link  |  Quote  |  Print  |  Notify Moderator
I stand corrected! You learn something new everyday!
2001 Dodge 3500 DRW V10 Magnum
2002 Sunline T280SR
Arrow Hensley Hitch
10' Porta Bote
My photo galleries.
Flyfisherman128
Broadalbin, NY
Posted: 06/17/08 08:24am Link  |  Quote  |  Print  |  Notify Moderator
The Qbaby has no side tables the Q100 does. The Q120 has electronic ignition. The Q has less btu's than the 200 and the 220 has electronic ignition. I have had the baby Q for three years and I just bought the 200 last weekend..love them both...by the way I added side tables and electronic ignition to my Baby Q. all the parts are inter changable.
SWMO
Southwest Missouri
Posted: 06/17/08 09:08am Link  |  Quote  |  Print  |  Notify Moderator
The problem also lies in refilling the hose with gas, as opposed to air. The air in the hose is dispelled at the same rate that gas would be. You can avoid this by leaving the hose attached to the tank.
flyfisherman128, Weber no longer lists a Baby Q, only the 100's and while both have the ignition, the 120 has the shelves added.
2002 Ford F350 Crew, LB, DRW, 7.3L
Jayco Designer 34RLQS
Not a Clue
Southern Ca
Posted: 06/17/08 09:23am Link  |  Quote  |  Print  |  Notify Moderator
I just bought a Q100 last weekend, no side tables and it has an electronic ignation.
Linda B.
2006 31' Fleetwood, TiogaSL - The Big Bus
2008 Saturn Vue (Toad)with US Gear UBS
& Demco baseplate and tow bar.
Traveling with Robin(friend),Liz(cockapoo)&Buddee(cavalier)
swebber
Brunswick , MD
Posted: 06/17/08 10:59am Link  |  Quote  |  Print  |  Notify Moderator
Same here. My Q100- No tables and has excellent electronic ignition. My new Q200 has tables and the same great ignition system.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
davosfam
SW Washington
Posted: 06/17/08 11:30am Link  |  Quote  |  Print  |  Notify Moderator
How many quarter pound burgers can fit on the 100 vs. 200? And how many large rib eyes?
Shannen (and hubby Rick)
2 sons, ages 15 and 19
2 dogs, "Duncan" (mini schnauzer) and "Libby" (lhasapoo)
1996 GMC Yukon
1986 Kit Road Ranger 234
1965 Chevrolet Bel Air
1948 Plymouth 2-door sedan
2005 Honda Foreman 500
wny_pat
Western NYS
Posted: 06/17/08 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
You can do a easy 6 quarter pounders, maybe ever 8 if you squeeze tight, on the 100. Rib eyes would depend on size of the steaks.
SWMO
Southwest Missouri
Posted: 06/17/08 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
I believe you could get 4 ribeyes on it, probably 6 small ones. You would probably have to turn them in a different order to be sure of even cooking.
gtojohnny
Monterey
Posted: 06/18/08 11:49am Link  |  Quote  |  Print  |  Notify Moderator
I noticed that when connected to a 20 lb. tank instead of a little bottle, it cooks very hot even at the lowest setting.
