RV.Net Open Roads Forum: Travel Trailers: jayco tire clearance 08 25F
 > jayco tire clearance 08 25F
larryn
mpls. mn
Posted: 06/17/08 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone questioned the clearance above their tires and the floor of the trailer? My 08 25f with Dexter torsion axels only had an 1 and 1/2 inches. Dexter recommends 3 inches.Jayco has agreed to replace the axels to provide proper clearance.Any comments or Quetions are most welcome.
pdvandusen
Snow Hill, NC USA
Posted: 06/17/08 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem with my 2008 JayFeather 31E. They changed the axles and all 4 tires. My clearance was only 1/2". After the fix, it's working just fine.
Doug & Mary Ann Van Dusen and Phoebe (the dog)
2008 Chevy 1500 Silverado 5.3L LTZ 3.73, HD Trailer Pkg.
2008 JayFeather LGT 31E
Equal-i-zer, Prodigy BC and TomTom GPS
subourbon
Huntsville, AL
Posted: 06/17/08 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Doug.......my axles are finally settling. Jayco says its a bushing problem in the axle that's failing and causing the axle to settle. They have notified Dexter about their concern, mean while it's a warranty replacement. My new axles are on order.
Happy Camping
2007 Chev. Silverado CrewCab 4x4
6.0L Vortex Max
3.73 Rear Axle Ratio
Prodigy Brake Control
Equalizer Hitch
Champion 4000/3500 30A RV Gen.
Garmin 7200 GPS
2008 31E Jayco Feather LGT
UVW6225 GVW7850
ROBINS NEST
BJ & Stan
Glen Allen VA
Posted: 06/17/08 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
after seeing pdvandusen's post on his clearance I checked mine and only had about 3/4" clearance. I e-mailed Jayco about my 31V and after about 21/2 weeks they called and said the axle's needed to be replaced. My only problem was that the dealer was booked until after we return from vacation so I have an appointment to drop it off then and get the new axles put on.
Jayco 31V with a 2004 GMC Yukon 5.3L
johnthecamper
Grapevine, Texas
Posted: 06/17/08 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
I too have had a problem with tire clearance. Mine has about 1 1/2 to 2 inches and the front right tire is rubbing the paint off the underside of the fender from rubbing when going over bumps or dips. I have emailed Jayco and waiting for a response. Did they voluntarily offer to replace the axles or did you have to argue?
08 F250, 08 Jayco 29D
subourbon
Huntsville, AL
Posted: 06/18/08 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
Those of you that are having problems, when you call Jayco as for John Johnston. He is a Good Tech Rep and knows about this problem. I didn't have any problems with Jayco on the replacement, however, you might have problems with your dealer on getting the parts on order and the repair done. My dealer got with Jayco immediately so I guess I pretty lucky.
Happy Camping
sheepherd
Northern Indiana
Posted: 06/20/08 06:31am Link  |  Quote  |  Print  |  Notify Moderator
Thanks larryn for the heads up on the Feather problem.
I'm going to check my 2008 25F tire clearance today.
Pat
ArnieJ-NH
N. Swanzey, NH
Posted: 06/20/08 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Just checked my 25F - 1 3/4" at partial load. I'll see next week after we fill it up for a trip as to what it is a full load. That will give me a good bench mark.
Arnie & Mary
2004 4WD Dodge Durango w/5.7L Hemi/3.55/Tow Package
Reese WDH w/Dual Cam, Prodigy Brake Controller
2008 Jayco JayFeather 25F LGT
USAF (Ret) 1962-84 B-52D/G & FB-111A
Ham - N1BAC
My Traveling Web Page
sheepherd
Northern Indiana
Posted: 06/20/08 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
My Feather 25F measures about 1 3/4 to 2 inches with a very light load.(All tanks empty and not packed for a trip).
How are you all doing the measuring?
Should I call Jayco first or my dealer?
Pat
larryn
mpls. mn
Posted: 06/21/08 07:19am Link  |  Quote  |  Print  |  Notify Moderator
I took mine to my dealer, they sent pictures to Jayco.Jayco shipped axels next day.should have trailer back in about 2 weeks.
