RV.Net Open Roads Forum: Fifth-Wheels: Bad smell in 5er - only when towing???
 > Bad smell in 5er - only when towing???
JBGizmo
Toronto, Canada
Posted: 06/17/08 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
We had a bad smell when we would arrive camping and it ended up being the water that was sitting in the water filter container. We finally removed the water filter and the holder and no more smell. We always use bottled water for drinking and use the water hookup for showers, we don't mind the impurities for showering. It really was a horrible smell with the water stagnating in the filter holder.
buck3870
WV
Posted: 06/17/08 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Cougar as well. It is the same as you describe. I noticed it the first time I used it. I think it is the rubber roof. If you walk up to the bedroom slide the smell is really strong above the slide. It has the smell anytime the slides are closed if they are open it has no smell. I installed tank flushers in all three tanks and flush them well so I don't think it is from the tanks.
Rvndave
Medina, Ohio
Posted: 06/18/08 03:34am Link  |  Quote  |  Print  |  Notify Moderator
This also could be a bad vacuum breaker. These are usually located under a sink. To control holding tank odors we have used bleach for years. We found bleach works much better than products made for removing these odors.
2003 Jayco 308fbs eagle 33' tt, towed by a 2003 Ram 3500 slt, quad cab dually, cummins diesel ho, trailer towing package, with 6 speed manual. Hauls better 1/2, 3 kids, myself, and a 2003 ez go clays car.. I have added so far, neon lights, clearance lights, back up lights, black light, lift kit, mud tires, and everything necessary to make the golf cart street legal. It's now ready to spend the winter in the garage for more mods. More neon, strobe lights, alarm, a pa system, maintance, and whatever else that comes along. This golf cart does wheelies and travels thru 7 inches of mud when need be. Two honda eu2000i gens twinned to supply the electrical power. Latest addition an 04 Honda Goldwing. [url]http://www.hometown.aol.com/rvnagain/myhomepage/profile.html[url]
Pickle2
Riva, Maryland,
Posted: 06/18/08 03:48am Link  |  Quote  |  Print  |  Notify Moderator
As you drive, the air flowing past the outside of the rig causes a negative pressure inside it. This vacuum will draw vapors from your gray tanks if the vent stacks (located under your sink areas) check valves do not function as designed. I would check these first.
Pickle at Pickldom.
Wife, Deb; Daughters: Brenna(13), Alysson(12)
Dog: Chocolate Chip (English Springer Spaniel) "Okay, in or out, but don't keep pawing at the door!"
03' Dodge, 2500, Long Bed, 4x4, HO Cummins Diesel.
2004 29BHBP Wildcat by Forest River.
estesbubba
Omaha, NE
Posted: 06/18/08 06:06am Link  |  Quote  |  Print  |  Notify Moderator
We have the trash under the sink and noticed an odor under there. We though it was the trash, but it didn't go away after taking it out. So, the sink valves could be the problem.
--bubba
2008 Keystone Cougar 291RLS 5er
2006 Dodge Ram 2500 QC CTD, 4x4, 48RE, Line-X
Draw-Tite 16K Slider, BedSaver, Prodigy
our website: our trips | my woodworking hobby
flhtse05
Pace, Florida
Posted: 06/18/08 06:22am Link  |  Quote  |  Print  |  Notify Moderator
I use the GEO method and also have the RV360 vents. No bad smells.
sandpiper1
Idaho
Posted: 06/18/08 06:27am Link  |  Quote  |  Print  |  Notify Moderator
I installed a Cyclone vent top from camping world for around $20. Takes care of all the odors.
1999 F250 Super Duty Lariat Crew Cab, V10, 4R100, Prodigy, Superchip, 4.10LS, Firestone onboard airbags, Reese 15K/3750pin, 2006 Forest River Sandpiper 315BHT.
Dave H M
IL
Posted: 06/18/08 06:33am Link  |  Quote  |  Print  |  Notify Moderator
I am sure this won't do it, but I took a trip once and had a smell in the trailer when I stopped. I finally traced it tothe oven knob being set to pilot and the pilot was not lit.
I got the cougar's cousin the laredo and it does not have any smells in it after a drive, neither did my other RV's.
I forgot to check your sig, but if the rig is new it just may be glue, caulk, carpet, etc that needs to age.
LA-REDNECK
GRAND BAY.AL, USA
Posted: 06/18/08 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Might want to check your batteries. They can give off a rotten egg smell when going bad. Smell is from hydrogen sulfide gas being off-gassed from shorted plated. etc.
LA-REDNECK
2002 GMC Duramax
2004 Jayco Designer Legacy
Fiver-Get-You-Ten
Chattanooga, TN
Posted: 06/18/08 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Have you checked to see if the last person out of the fiver before departure had a big grin on their face?
2007 DODGE RAM 2500 4x4 QC CTD 5.9 4SPD AUTO RIDE-RITES PRODIGY REESE 16K KWIK-SLIDE*** 2008 MONTANA 3400RL
