GreenMitsuE1
Cotter, Arkansas
Sureflow makes all sorts of fluid transfer pumps. The dealership I worked at last had one we bought from NAPA to pump fresh oil into deisel engines when we did oil changes. It worked great, and looked nearly identical to the water pumps we all see in rv's. I'd say that the difference would be the rubber "pump" parts. If you aren't to terribly concerned about ruining it, I'd give it a shot. Chances are it'll do the job.
_________________
Master Certified mobile RV tech ~ North central Arkansas
javaseuf
Southern Cal
The diaphram in a SureFlo is rubber and oil will attack rubber.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
Takereasy
South Texas near Victoria
Chris Bryant wrote: I don't think it will pump oil, it's just too thick. You need an impeller type pump, not a diaphragm type.
Really? We used Diaphram pumps to pump cold and hot engine oil everyday and they out perform most other pumps we've tried.
Visit our site
Jodi & Richard
98 Tiffin Allegro Bay 34' w/Slide
01 Ford Ranger 5 speed - US Gear Brake
00 HD E-Glide
My Last RV Rebuild
mchero
Concord, NH
Takereasy, Nice RV rebuild PICS.
Robert McHenry
Concord, NH.
1993 Fleetwood 36' Pace Arrow
Cummins 8.3l Turbo 300hp (uprated)
Allison 3060 Trans
http://dieselrvowners.com
Chris Bryant
DeLand, Florida, USA
Takereasy wrote: Chris Bryant wrote: I don't think it will pump oil, it's just too thick. You need an impeller type pump, not a diaphragm type.
Yeah- I was talking specifically about this type of low displacement high speed diaphragm pump, not in general.
It may well work, I just don't think it would work well.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
Hurricaner
Hurricane Utah
Quote: Yeah- I was talking specifically about this type of low displacement high speed diaphragm pump, not in general.
I tend to agree with Chris on this one as this diaphragm pump was designed to pump water. However in the industrial world diaphragm pumps are used to pump all kinds of nasty stuff as they don't have impellers to get clogged up and they are positive displacement pumps.
It might work fine, only one way to know for sure.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
Fulltimer50
Eloy, AZ
We use a RV pump to pump concentrated round-up from a barrel to a jug.
George
99F250XLT/SC/LB/4x2/3.73LS/gauges/JNB BypassReg/ Airlifts/Rancho 9000s/DS Predator Tuner/203*TS/Coolant filter/Jimmyjammers/Oilguard/4"turbo back/Suncoast tranny/BD EBrake.
06 Newmar Cypress 29KSRE 5th wheel, Mor/Ryde IS, Kodiac disk brakes
Raften
Northern Calfornia
Yes it will work, they work faster if the veg is heated to be thin.
Bubby's RV
CA
javaseuf wrote: The diaphram in a SureFlo is rubber and oil will attack rubber.
This would be my concern. The type of pump will work, but it might not work for long if the oil eats the diaphragm.
John, Winnebago Minnie 24V
Hurricaner
Hurricane Utah
The diaphragm material is santoprene which is resistant to oil, not as good as other materials but it would probably hold up for many years.
Sam
