RV.Net Open Roads Forum: Fifth-Wheels: I screwed up again.
 > I screwed up again.
Road Phantom
pa
Posted: 06/18/08 08:58am Link  |  Quote  |  Print  |  Notify Moderator
In an effort to avoid a long trip to the dealer and having to wait all day while they winterized my Alumascape last fall, my wife and I did it ourselves. What a mistake. I missed one of three low point drains, so everything above it must have froze solid. None of the intake water valves work. The water comes gushing out, so now I'll have to take it in and have it fixed. I suspect it will cost a bunch.
I don't plan to use the trailer until October when I will haul it to a permenent spot in the RGV, texas. If the repair estimate is too costly, I thought I would just hook up the city water since that will be all I would need anyway. Any guesses as to what I'm up against. The tanks won't fill and the lines don't get any water, it just drains out somewhere above the low point.
portablevcb
Tijeras, NM
Posted: 06/18/08 09:08am Link  |  Quote  |  Print  |  Notify Moderator
It all depends on where the line(s) broke. And, yes, there may be more than one line split.
It's too bad you got hit like this. It is a real pain.
2006 Toyota Tundra Crew Cab
2003 Skyline Nomad 24ft Fiver
Me and Wife
Maggie the Old English Sheepdog
Chuck&Gail
In the Colorado Mountains
Posted: 06/18/08 09:57am Link  |  Quote  |  Print  |  Notify Moderator
What a bummer. Too late for you now, but that is why many of us use antifreeze in lines. It is cheap insurance.
I suspect city water connect will leak the same. If not, you know where leak is as there is normally very very little city vs pump seperate water lines.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
ChainReaction
Maine
Posted: 06/18/08 11:46am Link  |  Quote  |  Print  |  Notify Moderator
As long as you drained the water heater, water pump and freshwater tank, your damage should be minimal. They usually split the fitting at the shower and occasionally one or two other fittings. The lines themselves rarely split. Most freeze-up repairs only take about two hours plus a few fittings.
outdoorsman2007
In the Woods - Somewhere!
Posted: 06/18/08 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
The lines are easy to replace. They are probably push to connect which you can find at lowes or homedepot. If they want an arm and a leg for it, then do it yourself.
Dennis M M
Geneva, IL
Posted: 06/18/08 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with Chuck - running anti-freeze into all the lines is easier than draining and blowing out the lines
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'05 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro;
Optima Batteries
