halfstar
Farmington NM
Hello to all:
We are wondering if we use treated wood to place under our tires while it is parked by our house, will the chemicals in the wood deteriorate the tires?
Polishnurse
Schodack, NY
I don't think it will, but if you concerned, put and piece of rug on it or a plastic mat or bag. the drive up on it. Bill
Hamops
Oshawa, ON, CA
Good question but to date, I haven't noticed the tires having been affected by the pressure treated wood. The wood planks that our 5vr sit on during winter storage have sort of weathered and I don't think that there is much surface treatment left, if any.
Helen & George VE3INB and Max (Bichon Frise)
06 Silverado LT 2500HD D/A
2006 Crossroads Cruiser CF30SK
Prodigy Brake Controller
16K Reese Slider with a Bedsaver
BillnBama
Spanish Fort, AL
I had mine on treated 2x10s for a year and a half with zero affect on the tires... replaced the tires because of age (and my paranoia), but the tires are now on a 3/4 ton work truck and are doing just fine...
Bill & Jennifer
SKP #98005
2003 Dodge Ram 2500 QC, LWB 4x2, HO CTD, 48RE, 3.73 LSD
4" MBRP SS Exhaust, S&B CAI
2005 Cedar Creek Silverback 28LRLFS
MAJESTYPOINTERS
MONROE, MI.
I just paint my wood blocks with white paint...It seams to help even treated wood last longer. It also makes them easy to see if I am working with them at night....
I Know I had at least one more leveling block...
Now Where did it go
Dayle1
Spicewood, Tx
For 10 yrs, my RV storage has had gravel under one side of the tandem axles and treated boards under the other. My last fiver had two tires fail at different times, one on each side. Also haven't noticed any difference in tire wear, so my experience tells me it makes no difference.
Larry Day
Texas Baptist Men-Retiree Builders since '01
'03 GMC 2500HD D/A EC SB, Jordan controller, custom RKI bed/hitch, Putco boards, TF 45gal tank, grey Speedliner
'04 CrossRoads Cruiser CF29RK, Mor/ryde IS, Carefree Eclipse 12V awning
Rig Photos
DutchmenSport
Indiana
Been parking RVs on treated lumber for approximately 10 years. No problem at all. My tires never touch the ground unless they're on the road or in the campground.
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
ralexis
Flagstaff, AZ
Caution! Birth defects in tires have been known to happen when stored on treated lumber.
LSU Tiger Fan
Retired U.S. Air Force
Pretty good Cajun Cook
Fair Skeet Shooter
Over-the-Hill Skiier
One Lovely Wife
Two Ugly Sons
Six Beautiful Grandkids
One Lucky Dog
SoCalDesertRider
SanDiego, CA, USA
ralexis wrote: Caution! Birth defects in tires have been known to happen when stored on treated lumber. Studies by the National Institute of Tire Health have shown that treated wood can cause a certain form of tire cancer too, according to the US Tire General.
Also, tires who are nursing should not consume treated wood, and remember, the legal age for consuming treated wood is 21 in all states. Be prepared to show your ID if your tires look under 30.
Oh, and no tires who have been consuming treated wood should ever operate a motor vehicle or any kind of dangerous equipment, like a torque wrench or hydraulic floor jack.
If your tires are stopped by a law enforcement officer and the officer has reason to believe your tires have been consuming treated wood, they will be required to pass a field inspection and air pressure test. If the tires refuse a field test, they can be arrested and put in tire detention before being sent to Tire Court, which is presided over by the Chief Justice of Tire and Rubber Products.
You have been dually warned (pun intended)...
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
John3872
Iowa
Like everybody else had said, I haven't had any problems with treated lumber.
2001 GMC 2500 6.0L
2006 Rockwood 8281SS
Reese 16K Fifth Wheel Slider
DrawTite Brake Controller
