RV.Net Open Roads Forum: Class A Motorhomes: Electric hookup
 > Electric hookup
Mikemarci
Portland, Oregon
Posted: 06/20/08 06:25am Link  |  Quote  |  Print  |  Notify Moderator
Heading out on our first trip , 99 Southwind. Checking list twice etc, do we need any adapter or cord for the electic hook up at sire? We have the balck cord in the Rv but am wondering if we are missing something.
Thanks
Sully2
Cincinnati
Posted: 06/20/08 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Thanks
Make sure you have a 30 amp to 15 amp converter plug / pigtail.
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
Hikerdogs
Wisconsin
Posted: 06/20/08 06:34am Link  |  Quote  |  Print  |  Notify Moderator
If you have a 30 amp cord ( 3 prong plug with the terminals arranged in a triangle) you probably will do just fine. Almost all campgrounds have 30 amp setvice. If you have 50 amp (4 prongeed plug) you will need an adaptor to use a 30 amp service. Some campgrounds have a limited number of 50 amp sites. I wouldn't be too concerned though since almost every campground store carries any adaptors needed in their park.
Hikerdogs
2001 Winnebago Adventurer
Fire Instructor
Upstate (Albany) NY Area
Posted: 06/20/08 06:36am Link  |  Quote  |  Print  |  Notify Moderator
If you have a 50 amp (typically a larger RV) connetion and the CG only has 30 amp service, you will need an adaptor. Parks that have this limitation often have the necessary adapter for sale, or sometimes you can "rent" them from the CG.
Fire Instructor
2004 Dodge 1500 4dr 4x4
2009 Rockwood 2607
"If everyone is thinking alike, then somebody isn't thinking!" General George S. Patton
D & M
Laurel, MD
Posted: 06/20/08 06:46am Link  |  Quote  |  Print  |  Notify Moderator
You didn't say if you had a 30 or a 50 amp service. If you have a 50 amp service in your rig, you should get a 50 amp to 30 amp adaptor also. Click here
This will cover you in case you go to a place where they don't have 50 amp service available.
If you have 30 amp service in your rig, you are good to go.
One other thing you may wish to consider is getting a device to protect the electrical circuits and equipment in your rig. Look into one made by Surge Guard or Progressive Industries. They protect against power spikes, incorrect wiring in the campground circuits, and hi/low voltage conditions (which are common).
Dave & Mary
Isabel (a cuddly little Boston)
Buddy (The Beast) another Boston
2005 Itasca Suncruiser 35A
2003 Jeep Liberty
If it's listed in the Yellow Pages, the government shouldn't be messing around with it.
urmine351
fort smith, arkansas
Posted: 06/20/08 06:48am Link  |  Quote  |  Print  |  Notify Moderator
It would be good today to go out and make sure everything is working...ref.water heater, water pump, stove, air conditioners, generator. start the generator( be sure and check oil level first) open the propane valve at the tank, and you should be able to check everything out.
It's friday, you can still get parts and get stuff fixed, it's much easier to take care of any problems before you hit the road.
The others have talked about your shore power, so all I can say is welcome to the forum and have a wonderful maiden trip.
1996 Safari Serengity, 3126 Cat,Allison 6 speed, 38' DPNS, 2005 Honda Element,vip tow brake. doran tire sensors, Magellan750Nav,
and 1 good looking wife, and missy and Alex(died 11-03-06) and AJ, born 09-06-06 my carins.
FMCA # F374886
Lovedays
Greensboro, NC
Posted: 06/20/08 06:58am Link  |  Quote  |  Print  |  Notify Moderator
I suggest that you get at least one extension cord to keep with you. I know you can get a 30 amp cord at Wal-Mart, but I've never looked into 50 amp.
I have not needed it a lot, but I did need one the first time I used my HTT. It was really frustrating to get all set up only to realize my cord didn't reach all the way to the outlet.
Have a great trip!
Eric, Melissa, Morgan, Andrew
and Sam the Camping Canine
2006 Starcraft Antigua 235SRG
2004 Toyota Tundra SR5 Double Cab V8
www.thelovedays.com
Wherever I happen to park
Posted: 06/20/08 10:18am Link  |  Quote  |  Print  |  Notify Moderator
I carry a full range of adapters from 50-30, 30-50 15-30 and 15-50 and 30-15 (in all cases that's plug to outlet)
That way I can plug most anything in most any place
Chuck&Gail
In the Colorado Mountains
Posted: 06/20/08 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 30 amp rig, and have had to use a 50-30 adapter more than once because only 50 amp outlet was available. Note many post above use words like "most" or "usually". So how much of a gambler are you? I carry all adapters I can use, and have used them all at one time or another.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
billbrit
Nevada
Posted: 06/21/08 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
We bought our first motorhome and it didn't have an extension cord to connect to shore, so I bought one at CW for about $40.00. I threw it in the RV and headed out for our first trip. After we got set in our space I tried to connect, only to discover we had that rare motorhome that requires a 'Marine Connection' to the rig, so my extension was no use. We fished up driving the coach through the town looking for an RV shop that had a suitable cord. We found one and it was $175.00. Of course there's a lesson here. Check that you not only have the cord, but that it's the right cord.
 > Electric hookup
