RV.Net Open Roads Forum: Toy Haulers: HELP!
Search only in Toy Haulers
 > HELP!
MG at FEW
Wyoming
Posted: 06/20/08 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
IS THERE ANYONE OUT THERE THAT I CAN CALL TO WALK ME THROUGH TROUBLESHOOTING? I'm trying to get my rig, see sig, ready to go tonight. I started flushing the water system and while the tanks were filling I re-installed the three 12v batts. The gauge (idiot lights) in the rv came up dim and then went completely out. I have power to all the interior lights and water pump. I have turned on the LP gas to start cooling the fridge, but nothing is coming up on the lights. I also can't get my gen to even crank. IS THERE ANYONE OUT THERE THAT I CAN CALL TO WALK ME THROUGH TROUBLESHOOTING?
One Wife, two daughters and two BIG GSDs
04 F-350 PSD, SRW Short Bed, 5 inch Bully Dog Exhaust
Polaris Sportsman 700 (mine)
Polaris Sportsman 400 (hers)
2006 Jayco Talon F35Y
Prodigy Brake Controller
Husky 24k Slider
gouldc
Edmonton, Alberta Canada
Posted: 06/20/08 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hey there.
Just to clarify, your problem is with the sensor panel and the fridge correct? SOC on the batteries? How about a voltage reading across a 12v circuit?
03' Lariat F350, 6.0L Short Box *SOLD*
04' Jayco Eagle 28FKS *SOLD*
08' FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
07' Keystone Raptor 3712TS PICTURES
Reese 18k Signature Series Hitch
rich racin
Easton,Pa
Posted: 06/20/08 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
if you can check the battery voltage ,one battery at a time. May need charging or replacement.The voltage should be approx 12 volts or more
Rich & Karen
1999 Coachman Santara
Malibu Tow'd
broccoli2
Valencia CA
Posted: 06/20/08 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
If everything was working fine before.... Disconnect new batt's... Make sure your main 12V power switch is in the off position. Have a beer and clear your mind of when you hooked them up..... Rehook it all up paying attention to making sure the positive is on positive and the neg is on neg (all 12V correct?).. Sometimes you might have just made a bad connection and this will solve all the problems.. turn back on the 12V system and give her a try..
Good luck
2007 F350 4X4 Smoker
2007 WW FSC3200
2008 Yamaha WR450f
2005 TRX650GSA 4X4 Rincon
1946 CJ2a Frame off
2008 Yamaha Raptor 250
2006 Yamaha TTR125L
2007 Yamaha Wolverine 450 4X4
2006 Honda CBR 600RR
rcchallenger
La Mirada, California
Posted: 06/20/08 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
I would disconnect the three batteries and perform an independent voltage test on each battery. Chances are one of the batteries may have a dead cell. I had a dead cell on one of my batteries and it pulled the other battery down pretty fast.
If the batteries are okay reinstall and be sure they are connected parallel and be sure all of the grounds are good.
2005 Ford F350 XLT 4X4 SRW Powerstroke Diesel Firestone Air Bags
2006 Keystone Raptor 3612DS
2006 Yamaha WR450
2006 Yamaha YFZ450
2005 Yamaha TTR230
2006 Kinroad XT250CC Go-Kart
MG at FEW
Wyoming
Posted: 06/20/08 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Somewhere there is a village without it's idiot...said idiot is me. When I hooked up my batts I was looking at a picture from last year. When I put the bats in, they were backwards from last year. I had the batts wired backwards. I realized it when I went to open one of the vents on top via switch...up went down and down went up. Thank you all for your speedy replies. If you are ever in the need of an idiot, please let me know.
Thanks
The idiot formerly know as glen
John3872
Iowa
Posted: 06/20/08 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Don't feel back I did the same thing a couple of years ago. Thought the battery was no good and bought a new one. Same problem, After a couple of hours of messing with things I realized that I had them hooked up backwards.
2001 GMC 2500 6.0L
2006 Rockwood 8281SS
Reese 16K Fifth Wheel Slider
DrawTite Brake Controller
gouldc
Posted: 06/20/08 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Don't worry about it, that's what we're here for. I know the state you're in, prepping for that trip out, way too much on the mind. Small, simple things get missed. Will make for a great laugh around the fire tonight!
rcchallenger
Posted: 06/20/08 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
Gald things worked out okay. My dad used to tell me to look for the simple solutions first. It's an easy mistake when you're rushing around getting ready for a trip.
Have fun. Wish I was going somewhere instead of working.
broccoli2
Valencia CA
Posted: 06/21/08 07:51am Link  |  Quote  |  Print  |  Notify Moderator
glad to here it was a simple fix
 > HELP!
