RV.Net Open Roads Forum: Travel Trailers: pressure rating on new trailer tires
 > pressure rating on new trailer tires
daveasch
Pueblo, Colorado
Posted: 06/20/08 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
I just replaced the tires on my TT. Both the old and new set were/are Denman Express ST 205/75R/15's. Here the thing: the old set were stamped with a max rating of 65 psi. The new ones say 50 psi. Any idea why the change? Should I go with what is stamped?
Thanks!
2001 Innsbruck 30DBR
2004 Chevy Suburban K1500 5.3L
Myself, my wonderful wife, and 4 great kids!
"Someone has to live in Colorado, it might as well be me"
Chuck&Gail
In the Colorado Mountains
Posted: 06/20/08 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
Likely old tires wwere load range D. New tires are load range C. Note if so they will not carry near as much weight!!!!!
Better check your weight capacity begfore you drive anywhere.
Note over inflating tires just makes them MORE dangerous. IMO you should never exceed sidewall pressure ratings (on ST or P rated tires).
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
JJBIRISH
Butler, PA, USA
Posted: 06/20/08 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
YOU BETTER CALL THE TIRE SHOP AND TELL THEM TO PUT YOUR OLD TIRES BACK ON UNTIL THEY GET THE RIGHT ONES FOR THE TRAILER...
you may have a very dangerous situation there... and until you find out I wouldn't take it anywhere...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
tvman44
Southwest Louisiana
Posted: 06/20/08 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with Chuck and Gail> Better call tire shop and tell them they put the wrong tires on your trailer.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
johntank
Oxford, Ms 38655 USA
Posted: 06/20/08 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
I agree that the old tires were a load range D tire witch carries the 65 psi max rating and the new ones are just a load range C with the 50 psi rating.
I think you need to check the load rating in lbs to see if the new tires are the same as the old tires, I'm thinking they will be lower. JMHO
daveasch
Pueblo, Colorado
Posted: 06/20/08 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, all. You nailed it. I'm glad I asked, and I'm glad you all answered so quickly. I know this will open a can of worms, but feel free to give me your opinion: since I'm headed back to the tire shop, should I consider getting bigger tires or even switch to LT's...
Dave
JIMNLIN
Big Cabin, OK
Posted: 06/20/08 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
what is the trailer GVWR ?? Above 7k-8k and you travel at interstate speeds I would switch to LTs if possible. Some have gone to a Maxxis ST225/75-15 D load range in place of ST205/75's. Your choice.
Jim
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
JJBIRISH
Butler, PA, USA
Posted: 06/21/08 12:30am Link  |  Quote  |  Print  |  Notify Moderator
you will have very few choices that will fit if changing sizes,, and it could get expensive to do...
you most likely have five inch rims... I wouldn't be afraid to use the 225x75x15 in LR D, even though they should be on six inch rims...
Turbo Diesel Dude
Green Mountain, NC
Posted: 06/21/08 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Maxxis ST225 75R 15 Load Range E. Better IMHO
charles weidman
JJBIRISH
Butler, PA, USA
Posted: 06/21/08 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
not necessarily... but a popular misconception...
if his rims are only rated for 65PSI and he runs LR E's at that 65 PSI the load capacity for the tire is the same as the LR D's...
