RV.Net Open Roads Forum: Travel Trailers: Anode Rod
 > Anode Rod
jf504mp
Indiana
Posted: 06/21/08 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
Where is the anode rod in an Atwood water heater, a 6 gallon one?
chassis
Penn's Woods
Posted: 06/21/08 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
I've had the same anode for 5 years. We use our TT about 2 weeks per year. The anode rod is 85% intact. I remove it from the water heater when I winterize. I'll probably get a new one next year, although it likely won't be necessary.
2003 F-250 6.0 Powerstroke diesel, 4x2, crew cab short bed
2004 Cardinal T31BH travel trailer
jhinojosa
Brownsville TX
Posted: 06/26/08 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
Do all TT water heaters have the anode rod? When I picked up my 2008 Jay Feather LGT 25F, I asked the service guy about it and he said it didn't have one. My 2008 Casita had one.
Thanks.
2008 Jayco Jay Feather LGT 25F
2008 GMC Sierra SLT 2500HD Crew Cab Duramax/Allison
NCHornet1
Mt. Airy, NC.
Posted: 06/27/08 07:47am Link  |  Quote  |  Print  |  Notify Moderator
I would probably shoot for less than 50% this will give you some room if you can't get a replacement. It would be a good idea to just do it every spring, they aren't that much money.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
jhinojosa
Brownsville TX
Posted: 06/28/08 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Thanks.
Got home to check Atwood manual and no anode rod is used in their 4, 6, 10 gallon models (4E & 10E). Winterizing (Flushing) instructions and parts list also do not ention or list an anode rod.
You all have a great day!
BarneyS
S.E. Lower Michigan
Posted: 06/28/08 10:47am Link  |  Quote  |  Print  |  Notify Moderator
The Atwood water heater does not use an anode rod. The tank is aluminum clad and does not require one. In fact, if I remember correctly, Atwood says that the use of one will void the warranty.
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the new RV.net Blogs!
Visit our website here
 > Anode Rod
